Problem with an AF9035 device
tango_
usbtuner -V
On the server I've released the 0.2.9 version who correct a big bug.
this version is the use
root@bm750:~# usbtuner -V
UsbTuner v0.2.9
angelofsky1980
BlackHole Driver Specialist
usbtuner -V
UsbTuner v0.2.9
Could you please post the output of these commands?
cat /proc/bus/usb/devices
and
cat /proc/bus/nim_sockets
Thank you
tango_
OpenEmbedded Linux bm750
Vuplus 2.0.3 bm750
bm750 login: root
root@bm750:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S: Product=BRCM OHCI
S: SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S: Product=BRCM EHCI
S: SerialNumber=ehci-brcm
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0951 ProdID=1624 Rev= 1.00
S: Manufacturer=Kingston
S: Product=DataTraveler G2
S: SerialNumber=0014780F995DF991265123F
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=31875us
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 3 Spd=480 MxCh= 0
P: Vendor=07ca ProdID=a835 Rev= 2.03
S: Manufacturer=AVerMedia TECHNOLOGIES, Inc
S: Product=A835
S: SerialNumber=3012341023456
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 5 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=86(I) Atr=01(Isoc) MxPS= 0 Ivl=125us
I: If#= 0 Alt= 1 #EPs= 5 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=86(I) Atr=01(Isoc) MxPS=3072 Ivl=125us
root@bm750:~# cat /proc/bus/nim_sockets
NIM Socket 0:
Type: DVB-S2
Name: BCM7335 DVB-S2 NIM (internal)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
root@bm750:~#
tango_
Vuplus 2.0.3 bm750
bm750 login: root
root@bm750:~# lsmod
Tainted: P
dvb_usb_af9035 13840 0 - Live 0xc0467000
dvb_usb 18832 1 dvb_usb_af9035, Live 0xc04b2000
bh_dvb_core 107312 1 dvb_usb, Live 0xc04d6000
tua9001 3664 1 dvb_usb_af9035, Live 0xc0452000
tda18218 3456 1 dvb_usb_af9035, Live 0xc0450000
af9033 18320 1 dvb_usb_af9035, Live 0xc0461000
mxl5007t 10320 1 dvb_usb_af9035, Live 0xc0455000
nls_iso8859_1 3840 1 - Live 0xc0144000
nls_cp437 5504 1 - Live 0xc042c000
ntfs 309536 0 - Live 0xc0517000
vfat 11776 1 - Live 0xc03f0000
fat 57520 1 vfat, Live 0xc040d000
sr_mod 16128 0 - Live 0xc03f7000
cdrom 43296 1 sr_mod, Live 0xc041d000
cifs 281808 0 - Live 0xc046c000
nls_base 7504 6 nls_iso8859_1,nls_cp437,ntfs,vfat,fat,cifs, Live 0xc03f400
isofs 25744 0 - Live 0xc0405000
brcmfb 3216 2 - Live 0xc0085000
fb 31072 5 brcmfb, Live 0xc03fc000
dvb_bcm7335 4341536 44 brcmfb, Live 0xc0613000
dvb_core 106224 1 dvb_bcm7335, Live 0xc0146000
procmk 1856 0 - Live 0xc0087000
snd_pcm 73504 1 dvb_bcm7335, Live 0xc010f000
snd_timer 24016 1 snd_pcm, Live 0xc00ee000
snd_page_alloc 8592 1 snd_pcm, Live 0xc00cb000
snd 53552 3 dvb_bcm7335,snd_pcm,snd_timer, Live 0xc00df000
soundcore 9552 1 snd, Live 0xc00c7000
firmware_class 10688 1 dvb_usb, Live 0xc009f000
i2c_core 19936 5 dvb_usb,tua9001,tda18218,af9033,mxl5007t, Live 0xc0074000
evdev 9664 1 - Live 0xc0081000
input 24944 5 dvb_usb,dvb_bcm7335,evdev, Live 0xc008b000
usb_storage 40720 1 - Live 0xc0094000
sata_svw 17104 1 - Live 0xc007b000
libata 140448 1 sata_svw, Live 0xc00a3000
Thank you
angelofsky1980
Vuplus 2.0.3 bm750
bm750 login: root
root@bm750:~# lsmod
Tainted: P
Thank you
Seems all OK but I need also the output of
dmesg -c
Thank you for your patience.
tango_
Vuplus 2.0.3 bm750
bm750 login: root
root@bm750:~# dmesg -c
[VID]: VIDEO_STOP 1 1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: proc_get_ac3 0 bcm7335->audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[AUD]: bcm7335->audio_dec_ss.codec 1
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 2 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[VID]: VIDEO_CONTINUE 1 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0a05fcc
[AUD]: setting mute : 0
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 proc_get_ac3 0 bcm7335->audio_passthrough_spdif : 0
[AUD]: bcm7335->audio_dec_ss.codec 7
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_PLAY 1 5 2
root@bm750:~#
thank you teacher for their hard work
angelofsky1980
Vuplus 2.0.3 bm750
bm750 login: root
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
root@bm750:~#
I'm sorry... you should remove your USB DVB device, re-plug, and do the dmesg command, then report the output.
maigais
Hi, can we consider contacting the skaip of the
would firstly to ask a few questions about dvb-t driver
the main of "TUNER" FAILED "
tango_
Vuplus 2.0.3 bm750
bm750 login: root
out of order segment: rcv_next 38C8EEE seq 38C8F27 - 38C8F2F
out of order segment: rcv_next 38C8EEE seq 38C8F2F - 38C8F7C
ofo requeuing : rcv_next 38C8F27 seq 38C8F27 - 38C8F2F
ofo requeuing : rcv_next 38C8F2F seq 38C8F2F - 38C8F7C
out of order segment: rcv_next 1442F176 seq 1442F71E - 1442F72
ofo requeuing : rcv_next 1442F71E seq 1442F71E - 1442F728
[AUD]: AUDIO_STOP 1
FE tune
usb 1-2: USB disconnect, address 3
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
out of order segment: rcv_next 144538B6 seq 14453E5E - 14453EE
ofo requeuing : rcv_next 14453E5E seq 14453E5E - 14453EE2
Vuplus 2.0.3 bm750
bm750 login: root
root@bm750:~# dmesg
Ack 3725210521 out of 3725210541:3725210541
out of order segment: rcv_next 38CFA8A seq 38CFAFC - 38CFB35
ofo requeuing : rcv_next 38CFAFC seq 38CFAFC - 38CFB35
out of order segment: rcv_next 14468A76 seq 1446901E - 14469023
ofo requeuing : rcv_next 1446901E seq 1446901E - 14469023
out of order segment: rcv_next 38CFCCC seq 38CFCD4 - 38CFD3A
out of order segment: rcv_next 38CFCCC seq 38CFD3A - 38CFD7A
out of order segment: rcv_next 38CFCCC seq 38CFD7A - 38CFD82
out of order segment: rcv_next 38CFCCC seq 38CFD82 - 38CFE5F
out of order segment: rcv_next 38CFCCC seq 38CFE5F - 38CFEAC
ofo requeuing : rcv_next 38CFCD4 seq 38CFCD4 - 38CFD3A
ofo requeuing : rcv_next 38CFD3A seq 38CFD3A - 38CFD7A
ofo requeuing : rcv_next 38CFD7A seq 38CFD7A - 38CFD82
ofo requeuing : rcv_next 38CFD82 seq 38CFD82 - 38CFE5F
ofo requeuing : rcv_next 38CFE5F seq 38CFE5F - 38CFEAC
out of order segment: rcv_next 38CFFE7 seq 38D003D - 38D00D3
out of order segment: rcv_next 38CFFE7 seq 38D00D3 - 38D015B
ofo requeuing : rcv_next 38D003D seq 38D003D - 38D00D3
ofo requeuing : rcv_next 38D00D3 seq 38D00D3 - 38D015B
out of order segment: rcv_next 38D0566 seq 38D056E - 38D0604
out of order segment: rcv_next 38D0566 seq 38D0604 - 38D0778
out of order segment: rcv_next 38D0566 seq 38D0778 - 38D0879
ofo requeuing : rcv_next 38D056E seq 38D056E - 38D0604
ofo requeuing : rcv_next 38D0604 seq 38D0604 - 38D0778
ofo requeuing : rcv_next 38D0778 seq 38D0778 - 38D0879
out of order segment: rcv_next 38D0A7E seq 38D0B0B - 38D0C01
ofo requeuing : rcv_next 38D0B0B seq 38D0B0B - 38D0C01
out of order segment: rcv_next 38D15D2 seq 38D15DA - 38D1677
ofo requeuing : rcv_next 38D15DA seq 38D15DA - 38D1677
out of order segment: rcv_next 38D186A seq 38D1872 - 38D191D
ofo requeuing : rcv_next 38D1872 seq 38D1872 - 38D191D
root@bm750:~#
angelofsky1980
Vuplus 2.0.3 bm750
bm750 login: root
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
Vuplus 2.0.3 bm750
bm750 login: root
root@bm750:~# dmesg
root@bm750:~#
Have you followed the correct steps?
1. remove your stick
2. plug your stick
3. do "dmesg" command ?
tango_
Creating 7 MTD partitions on "bcm7xxx-nand.0":
0x0000000000000000-0x0000000007600000 : "rootfs"
0x0000000007600000-0x0000000007800000 : "kernel"
0x0000000007800000-0x0000000007c00000 : "boot"
0x0000000007c00000-0x0000000007d00000 : "cfe"
0x0000000007d00000-0x0000000007d80000 : "mac"
0x0000000007d80000-0x0000000007e00000 : "env"
0x0000000007e00000-0x0000000007f00000 : "nvm"
usbmon: debugfs is not available
ehci_hcd_brcm_init: Initializing 2 EHCI controller(s)
brcm-pm: enabling power to USB block
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-0)
drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
- USB h/w setup mode <B>
- USB power enable set for active HIGH mode
brcm-ehci brcm-ehci.0: BRCM EHCI
brcm-ehci brcm-ehci.0: new USB bus registered, assigned bus number 1
brcm-ehci brcm-ehci.0: irq 62, io mem 0x10480300
brcm-ehci brcm-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-1)
brcm-ehci-1 brcm-ehci-1.1: BRCM EHCI
brcm-ehci-1 brcm-ehci-1.1: new USB bus registered, assigned bus number 2
brcm-ehci-1 brcm-ehci-1.1: irq 57, io mem 0x10480500
brcm-ehci-1 brcm-ehci-1.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd_brcm_init: Initializing 2 OHCI controller(s)
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-0)
drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
- Resetting at b0480408
brcm_start_hc
brcm-ohci-0 brcm-ohci-0.0: BRCM OHCI
brcm-ohci-0 brcm-ohci-0.0: new USB bus registered, assigned bus number 3
brcm-ohci-0 brcm-ohci-0.0: irq 63, io mem 0x10480400
usb 1-1: new high speed USB device using brcm-ehci and address 2
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-1)
- Resetting at b0480608
brcm_start_hc
brcm-ohci-1 brcm-ohci-1.1: BRCM OHCI
brcm-ohci-1 brcm-ohci-1.1: new USB bus registered, assigned bus number 4
brcm-ohci-1 brcm-ohci-1.1: irq 64, io mem 0x10480600
usb 1-1: configuration #1 chosen from 1 choice
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usb 1-2: new high speed USB device using brcm-ehci and address 3
usb 1-2: configuration #1 chosen from 1 choice
usbcore: registered new driver pegasus
drivers/usb/net/rtl8150.c: rtl8150 based usb-ethernet driver v0.6.2 (2004/08
usbcore: registered new driver rtl8150
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
TCP bic registered
NET: Registered protocol family 1
VFS: Mounted root (jffs2 filesystem).
Freeing unused kernel memory: 140k freed
libata version 2.00 loaded.
brcm-pm: enabling power to SATA block
sata_svw 0000:01:00.0: version 4.0
ata1: SATA max UDMA/133 cmd 0xB0510000 ctl 0xB0510020 bmdma 0xB0510030 irq 4
ata2: SATA max UDMA/133 cmd 0xB0510100 ctl 0xB0510120 bmdma 0xB0510130 irq 4
scsi0 : sata_svw
Initializing USB Mass Storage driver...
scsi2 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
ata1: SATA link down (SStatus 4 SControl 300)
ATA: abnormal status 0x7F on port 0xb051001c
scsi1 : sata_svw
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl F0000)
ATA: abnormal status 0xD0 on port 0xb051011c
ata2.00: ATA-7, max UDMA/133, 976773168 sectors: LBA48 NCQ (depth 0/32)
ata2.00: configured for UDMA/133
Vendor: ATA Model: ST3500630AS Rev: 3.AF
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 976773168 512-byte hdwr sectors (500108 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda: sda1
sd 1:0:0:0: Attached scsi disk sda
sd 1:0:0:0: Attached scsi generic sg0 type 0
procmk_init
dvb_bcm7335: module license 'Proprietary' taints kernel.
$Id: bcm7335_init.c Ver. 0.1$
DVB: registering new adapter (BM750S)
isa bounce pool size: 16 pages
Vendor: Kingston Model: DataTraveler G2 Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sdb: 7827392 512-byte hdwr sectors (4008 MB)
sdb: Write Protect is off
sdb: Mode Sense: 16 24 09 51
sdb: assuming drive cache: write through
sdb: sdb1
sd 2:0:0:0: Attached scsi removable disk sdb
sd 2:0:0:0: Attached scsi generic sg1 type 0
usb-storage: device scan complete
bcm7335: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
[AUD]: Open sync channel for decode
DVB: registering adapter 0 frontend 0 (BCM7335 FE)...
[MPVR]: >> misc_pvr_init
input: dreambox remote control (native) as /class/input/input0
[LCD]: registered
[CI]:-BM750_PCB_2_1
[CI]: registered ci0
[CI]: registered ci1
[DFP]: registered dbox fp
[DFP]: bcm7335_i2c_write: Error 1114113
[DFP]: bcm7335_max_i2c_write: Error 1114113
[DFP]: Scart 4707 is found 4
[SC]: registered sci0
[SC]: registered sci1
bm750_system_time_set wakeup mode get
bm750_system_time_set wakeup mode get 0xc4
NTFS driver 2.1.27 [Flags: R/W MODULE].
ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x40000000 action 0x0
ata2.00: tag 0 cmd 0xef Emask 0x1 stat 0x51 err 0x4 (device error)
angelofsky1980
Seems you are not using a BlackHole image or a very old BlackHole image.
Please consider upgrade your image in flash.
Your device should be Avermedia TV Volar Green HD (07ca:a835)
The driver is correct but doesen't support yet your device. I will add it the next release in few days.
Stay tuned.
