problem with backup image blackhole2.13 duo2
char23
hey gus i have problem to take backup for the latest image blackhole2.1.3
iget this messsage from the box
it says clearly what the problem is in the last picture.
You don't have enough free space on your storage device for it to save the backup ;)
have you mounted your hdd from device manager ?
I made a similar mistake also.
I used a 1TB used before drive although it was fully deleted before I installed it into the duo2 on the duo2 it said it was only 380M/B of free space. Yes 380 M/B not G/B and defiantly not 1 T/B.
First time installing the hdd to your box first you need to initialise your hdd from your box then mount hdd
I have a similar problem. When use the Full back-up to USB plugin i got error.
Using BL 2.1.3 on Vu+ Duo2. With 750GB harddisk. 75% are on the HD are free. The drive are mounted (/media/hdd/), and I record to it all the time.
In the error message says No such file or directory
'/usr/lib/enigma2/python/Plugins/Extensions/BackupSuiteHDD/message.py'
And itäs correct, I don't have BackupSuiteHDD folder in /usr/lib/enigma2/python/Plugins/Extensions,
But BackupSuiteUSB
And the plugin also are the Full back-up to USB, strange ?
But BackupSuiteUSB
Solved the problem. Have to install both Full back-up USB and Full back-up HDD.
