Hi. Yesterday, I installed a hard disk (SSD, 120 GB) into the receiver (SATA Port) and install new image (3.0.9.C) on it. When the image was installed on the USB flash it was possible to mount internal hard disk to record the channel. But since I installed the image on the internal hard disk it has not been possible to mount it for channel recording! Sorry, my English is not good. Thanks.
This is 1st time that I heard that an image on internal HD drive. Usually , its on USB using Mboot as U did. Do U mean the recording path?
Is it possible to install an image on one of its drives and mount another one for channel recording if I partition the hard disk?
Solved. 1. Install eparted plugin 2. Delete partition 3. Create 2 partition 4. Install image on first partition 5. Mount second partition for channel recording Thanks.
