problem with CI modules restart my VU+ DUO 2 ( TURKSAT 42 E )
its also with MaxTV CI CAM/16E,same simptoms,..works for fews minutes,then restart enigma2,..
only on to up BH-214 works without restart--all after that works restart,..
on enigma2_crash_log its empty,..
now I put fresh BH301-F,and result its same,even on VTI-9X,..and older works without problem,..
You should report this issue to Vu+ (www.vuplus.com)
Your right even with 2.1.4 mine not working ... Only vti that's work with me without annoying restart.
Remove the module from the device.
Turn off the power switch on the back of the device.
Plug the device(Vu+Duo2) opened module
How your remove mudel ? Remove or replace?
Hi. You should not remove module!
Get the module and firmware folders from black hole 2.1.4 and then after new image install drag these to folders in to there locations. When asked do overiting for all files. Then last step change to hight bitrate mode on CI module setting. Any questions, ask
Sent from my D5803 using Tapatalk
I did what u said 100% and the vu still restart
I c
copied them one by one to make sure all is pased and still restart like my vuplus been attacked or somthing loL
And by th
and by the way my ci not working with 2.1.4 only with vti
