What vu receiver have you got?Mine still crashing just like yours any solution? I tried everything but nothin work.
You should report this issue to Vu+ (www.vuplus.com)its also with MaxTV CI CAM/16E,same simptoms,..works for fews minutes,then restart enigma2,..
only on to up BH-214 works without restart--all after that works restart,..
on enigma2_crash_log its empty,..
now I put fresh BH301-F,and result its same,even on VTI-9X,..and older works without problem,..
Its reported to VU+,...You should report this issue to Vu+ (www.vuplus.com)
I have vuplus duo2What vu receiver have you got?
Sent from my D5803 using Tapatalk
Your right even with 2.1.4 mine not working ... Only vti that's work with me without annoying restart.its also with MaxTV CI CAM/16E,same simptoms,..works for fews minutes,then restart enigma2,..
How your remove mudel ? Remove or replace?@Gimitryci hi remove the modules and when it is, the image worked. your help, thanks again
Hi. You should not remove module!How your remove mudel ? Remove or replace?
I did what u said 100% and the vu still restartHi. You should not remove module!
Get the module and firmware folders from black hole 2.1.4 and then after new image install drag these to folders in to there locations. When asked do overiting for all files. Then last step change to hight bitrate mode on CI module setting. Any questions, ask
copied them one by one to make sure all is pased and still restart like my vuplus been attacked or somthing loLHi. You should not remove module!
and by the way my ci not working with 2.1.4 only with vtiHi. You should not remove module!
when the mudel removed the vuplus does not boot.Remove the module from the device.
Turn off the power switch on the back of the device.
Plug the device(Vu+Duo2) opened module
Just stay on vti then.And by th
