problem with latest bh 2.00!!!
the problem is the hdd dont appear ,as there is no hdd initialize,in the menu /parametre/system i found disque dur but dont want to initialize ,when i want to read my movies and music in media player , doesn't work,and when i went to paths recordings,hdd/movie its show (emplacement inscriptible"writable location") that mean the hdd dont want to initialize ,even it is initialized in linux format(bh 1.7.9 work well)
OK,,,I have no idea how to solve this issue....sorry...:suda:!
you don't need to initialize your disc if you want to keep all data on it.
If it was already working with 1.7.9 it will work with new version too.
How are you trying to play/view your files?
the hdd dont appear while in 1.7.9 works well ,i play my files with media player or when i go to path recording ,i have a message error say:emplacement inscriptible(writable location)that mean the receiver dont read my hdd ,even i mounted him in device manager (media/hdd)
try to use ftp client to check files on your HDD. Can you see your files in /media/hdd folder using ftp?
What hdd do you have and how is it connected to your box?
Have you mounted any other drives or usb?
Can you see hdd size when it's mounted as media/hdd?
i have a external hdd 250 go by usb ,yes i can see hdd size ,in image info ,and in blu panel -hard disk ,i see hdd size (used 145 go )
Has it got external power supply or it's just powered through USB?
try the above - use total commander
http://www.vuplus-community.net/board/threads/release-tc-8-01-final-32-64.7484/
or filezilla:
http://www.vuplus-community.net/board/threads/filezilla.2514/
ftp to your box then click on hdd shortcut in root directory or go to media/hdd (obviously using ftp). Can you see any files in there? Can you copy any of them to your PC?
or filezilla:
he dont connect to ftp :s i think the problem in image because when i go to menu/setup/system/hard disk he dont want to initialize ,(error)
no, it's nothing to do with initialization.
you're not answering my questions - how can I help you then?
Send your box to me I'll fix it :lol:
Edit:
perform online update already released :)
Edit:
hhhhhhh thanks ,i wish i send my box to you ,but no problem if the box dont want me update 2.01 hh i must stay with 1.7.9 no problem
