sonc
Thanks for another great image. One thing I've noticed on my Vu+ Uno:
On the OSD settings screen (Blue, Blue, OSD Settings), items listed are:
1. Disable Lite Infobar
2. Show Infobar on Event Change
3. Enable Panic
When you go into OSD Setup by pressing Red, item 2 and 3 are reversed:
2. Enable Panic
3. Show Infobar on Event Change
So if you set "Show Infobar on Event Change" to "yes", when you save and go back to OSD Settings it shows "Enable Panic" as being enbled, not "Show Infobar".
3. Enable Panic
2. Enable Panic
