problem with tuner solo 2
iman_miri
hi
i 1 years have problem with tuner solo 2
all is ok im shure software or boot or some thing like that have problem and many people like me have this problem
i search fereqance and i have channel but another fereqance channel automatic deleted
and when that fereqance searched then another deleted
pls help me i check any image orginal and black hole and ....
Mick12334
Moderator
How are you searching?
Are you using the Manual Search option?
Have you got the Delete before scan option selected, as this is the only way channels should be deleted, when scanning.
iman_miri
no im not use delete
and for example when with dreambox editor i send list i have the all channel but some freqance dont have signal and then i should sarch this freqance and all is ok but now another channel dont have signal or deleted
i use usals and dont have swicher only one lnb and i change the lnb and cable and icheck all with another reciver and dont have problem
only in my solo 2 reciver i have this problem and some freqance in nilesat
