Problem with wireless network - tp-link
Image was attached in the bottom of all encryption algorithms is clear.
All the algorithms that try to be my test. tkip and aes and tkip+aes
There may be problems with ap/router
not Compatible with these models
But is the global standard
I had a similar problem this evening with my dm500hd and my Dlink G122 (rt73 device).
The only solution I've found is to set up a static IP address on the box: you can try this solution.
Hi all
i was going to buy the tp link adapter but after seeing this thread i'll pass this option
hope your problems will be fixed
Nader
