problema con Hauppauge WinTV MiniStick HD
Sorry Angelo, but maybe it was some misunderstanding, and I would like to explain my problems more accurate.
I presently have two sticks. PCTV HD mini Stick, and Hauppauge WinTV Ministick (not HD). Both of them working excellent on on my duo, but on uno none of them. On both boxes is installed last BP image(I use it only because of online update function). On uno devices are recognized and installed properly, but during scan of terr. channels with PCTV HD mini Stick, does not find any channel, and Hauppauge WinTV Ministick find them all, but when I switch to any of terr. channels I got message "Tune failed". I also noted that after last online image update that after scan with Hauppauge WinTV Ministick I got picture on some channels(not all), but after restart of box again the same (no picture on any channel), until I rescan terr. channels again.
Is there any way to make that any of that two sticks start working properly on uno, or I have to buy some other stick for that box.
Any help is highly appreciated.
Thanks in advance, and best regards
About PCTV HD Mini Stick: I need the output of this command to discover what driver is used:
cat /proc/bus/usb/devices
About Ministick: HD or not HD versions are SAME and describe only the presence of Windows HD codecs.
I will make some tests with Ministick, Uno and BP.
Hi Angelo
Thanks for reply, and explanation.
Presently I can not send you requested output because uno is in another apartment, but I will post it by the end of next week.
Also would like to know if anybody can confirm that any of those two devices working properly on any version of any image on vu+uno.
Thanks, and best regards
Hi Angelo
It's impossible to determine without direct tests if a device works correctly on other images.
Hi Angelo
Just to advise you that after today online update booth devices working fine.:dance:
If you still need output of command cat /proc/usb/devices I will post it, but I don't know how to capture telnet output.
Thanks and best regards
Ministick:
root@vuultimo:~# cat /proc/bus/usb/devices
T:  Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0001 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ohci_hcd
S:  Product=Broadcom STB OHCI
S:  SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=  2 Ivl=255ms
T:  Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ehci_hcd
S:  Product=Broadcom STB EHCI
S:  SerialNumber=ehci_hcd
E:  Ad=81(I) Atr=03(Int.) MxPS=  4 Ivl=256ms
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  1, #Iso=  0
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 4
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=05e3 ProdID=0605 Rev= 6.0b
S:  Product=USB2.0 Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E:  Ad=81(I) Atr=03(Int.) MxPS=  1 Ivl=256ms
T:  Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#=  4 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=0930 ProdID=652a Rev= 1.00
S:  Manufacturer=TOSHIBA
S:  Product=TransMemory
S:  SerialNumber=0AD0885081030940
C:  #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=200mA
I:  If#= 0 Alt= 0 #EPs= 3 Cls=08(stor.) Sub=06 Prot=50 Driver=
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=83(I) Atr=03(Int.) MxPS=  64 Ivl=1ms
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#=  3 Spd=480  MxCh= 0
P:  Vendor=2040 ProdID=c000 Rev= 0.01
S:  Manufacturer=Hauppauge Computer Works
S:  Product=WinTV MiniStick
S:  SerialNumber=4033985691
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=smsusb
