huskyfirst1
I installed BH 3.0.4 on my VUPLUS SOLO2. but I encountered a problem with youtube, I have the sound but no picture on youtube. thank you
You can download new version from Black Hole and open Black Hole
plugins server
YouTube Git 350 (IPK Packages)(Black Hole E2)
If you have problems with the first video clip
exit and play again.
That's what I believe, only once.
Maybe registration.
If I go back to TV the black screen is also there. I see only in left top corner a small picture. If I press Teletext button and go back then I can see a full screen picture but not TV only frozen youtube picture (I'm in TV mode). After channel changing I can see TV picture in normal size.
Dear Sir,
Many thanks for your report and it has been recorded.
Our development team will review this report and contact you via e-mail if any follow up information is required.
Your valued bug report will help to us to investigate this issue and we would try to fix in a short time.
Best Regards.,
Vu+ Team
It does not work for me..
That's not true, works 100% on solo 2 and BH 3.0.4 .
I have tested plugin with BH 3.0.4 and
VU+ Zero ,Duo2 ,ultimo 4K ,solo 4k, uno 4K,solo 2
all working.
Your plugin also works on Solo SE V2 with BH 3.0.4. I tested.
But there is a small problem for me with YouTube plugin - no Russian keyboard layout.
https://github.com/Taapat/enigma2-plugin-youtube
