Problemino Kodi 3.0.2
Questo è il log che mi dice di vedere:
2590976 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:03:34 T:1982590976 NOTICE: -----------------------------------------------------------------------
01:03:34 T:1982590976 NOTICE: Starting Kodi (16.1-RC2 Git:2016-04-06-528f9f8-dirty). Platform: Linux MIPS 32-bit
01:03:34 T:1982590976 NOTICE: Using Release Kodi x32 build
01:03:34 T:1982590976 NOTICE: Kodi compiled Apr 6 2016 by GCC 4.9.2 for Linux MIPS 32-bit version 3.19.0 (201472)
01:03:34 T:1982590976 NOTICE: Running on Unknown Linux Distribution 0.0, kernel: Linux MIPS 32-bit version 3.13.5
01:03:34 T:1982590976 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
01:03:34 T:1982590976 NOTICE: Host CPU: BCM7425B2 STB platform, 2 cores available
01:03:34 T:1982590976 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
01:03:34 T:1982590976 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
01:03:34 T:1982590976 NOTICE: special://masterprofile/ is mapped to: /media/hdd/.kodi/userdata
01:03:34 T:1982590976 NOTICE: special://home/ is mapped to: /media/hdd/.kodi
01:03:34 T:1982590976 NOTICE: special://temp/ is mapped to: /tmp/kodi
01:03:34 T:1982590976 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
01:03:34 T:1982590976 NOTICE: Local hostname: vuduo2
01:03:34 T:1982590976 NOTICE: Log File is located: /tmp/kodi/kodi.log
01:03:34 T:1982590976 WARNING: Unicode properties are not enabled in PCRE lib, support for national symbols may be limited!
01:03:34 T:1982590976 NOTICE: Consider installing PCRE lib version 8.10 or later with enabled Unicode properties and UTF-8 support. Your PCRE lib version: 8.36 2014-09-26
01:03:34 T:1982590976 NOTICE: load settings...
01:03:34 T:1982590976 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
01:03:34 T:1982590976 NOTICE: Change AESink retry count..
01:03:34 T:1982590976 NOTICE: AESink retry count - 1
01:03:34 T:1982590976 NOTICE: No Devices found - retry: 1
01:03:36 T:1982590976 NOTICE: Found 0 Lists of Devices
01:03:36 T:1982590976 NOTICE: Change AESink retry count..
01:03:36 T:1982590976 NOTICE: AESink retry count - 1
01:03:36 T:1982590976 NOTICE: No Devices found - retry: 1
01:03:37 T:1982590976 NOTICE: Found 0 Lists of Devices
01:03:37 T:1982590976 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:03:37 T:1982590976 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
01:03:37 T:1982590976 NOTICE: Default DVD Player: dvdplayer
01:03:37 T:1982590976 NOTICE: Default Video Player: dvdplayer
01:03:37 T:1982590976 NOTICE: Default Audio Player: paplayer
01:03:37 T:1982590976 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:03:37 T:1982590976 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
01:03:37 T:1982590976 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:03:37 T:1982590976 NOTICE: Loaded playercorefactory configuration
01:03:37 T:1982590976 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:03:37 T:1982590976 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:03:38 T:1982456912 NOTICE: Change AESink retry count..
00:03:38 T:1982456912 NOTICE: AESink retry count - 1
00:03:38 T:1982456912 NOTICE: No Devices found - retry: 1
00:03:39 T:1982456912 NOTICE: Found 0 Lists of Devices
00:03:39 T:1982590976 NOTICE: Running database version Addons20
00:03:40 T:1982590976 NOTICE: ADDONS: Using repository repository.xbmc.org
00:03:41 T:1982590976 NOTICE: InitWindowSystem: Using EGL Implementation: vuplus
00:03:41 T:1982590976 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
00:03:41 T:1982590976 NOTICE: Previous line repeats 2 times.
00:03:41 T:1982590976 NOTICE: Found (1280x720@50.000000) at 16, setting to RES_DESKTOP at 16
00:03:41 T:1982590976 NOTICE: Checking resolution 16
00:03:41 T:1982590976 NOTICE: GL_VENDOR = Broadcom
00:03:41 T:1982590976 NOTICE: GL_RENDERER = VideoCore IV HW (V3D-420)
00:03:41 T:1982590976 NOTICE: GL_VERSION = OpenGL ES 2.0
00:03:41 T:1982590976 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
00:03:41 T:1982590976 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888
00:03:42 T:1982590976 NOTICE: Running database version Addons20
00:03:42 T:1982590976 NOTICE: Running database version ViewModes6
00:03:42 T:1982590976 NOTICE: Running database version Textures13
00:03:42 T:1982590976 NOTICE: Running database version MyMusic56
00:03:42 T:1982590976 NOTICE: Running database version MyVideos99
00:03:42 T:1982590976 NOTICE: Running database version TV29
00:03:42 T:1982590976 NOTICE: Running database version Epg11
00:03:44 T:1982590976 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
00:03:45 T:1982590976 NOTICE: ActiveAE DSP - starting
00:03:45 T:1982590976 NOTICE: initialize done
00:03:45 T:1982590976 NOTICE: Running the application...
00:03:45 T:1982590976 NOTICE: starting zeroconf publishing
00:03:45 T:1982590976 NOTICE: starting upnp client
00:03:45 T:1477440592 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
00:03:45 T:1477440592 NOTICE: UDP: Listening on port 9777
00:03:45 T:1982590976 WARNING: no keymap support (requires /dev/tty0 - CONFIG_VT)
00:03:47 T:1982590976 WARNING: Skin has invalid include: skinshortcuts-mainmenu
00:03:47 T:1982590976 WARNING: Skin has invalid include: skinshortcuts-submenu
00:03:48 T:1521706064 WARNING: Previous line repeats 1 times.
00:03:48 T:1521706064 ERROR: GetDirectory - Error getting include
00:03:48 T:1982590976 ERROR: Control 300 in window 10000 has been asked to focus, but it can't
00:03:49 T:1614804048 NOTICE: service.libraryautoupdate-0.9.8 : Update Library Service starting...
00:03:49 T:1614804048 NOTICE: service.libraryautoupdate-0.9.8 : update timers
00:03:49 T:1614804048 NOTICE: service.libraryautoupdate-0.9.8 : Creating timer for Video Library
00:03:50 T:1564472400 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
00:03:51 T:1564472400 NOTICE: script.tv.show.next.aired: ### no prior data found
00:03:54 T:1572861008 NOTICE: Skin Helper Service --> skin helper service version 1.0.68 started
00:03:54 T:1572861008 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
00:03:54 T:1469051984 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named cProfile
File "/media/hdd/.kodi/addons/script.skinshortcuts/default.py", line 6, in <module>
import cProfile
ImportError: No module named cProfile
-->End of Python script error report<--
00:03:55 T:1386374224 ERROR: GetDirectory - Error getting
00:03:55 T:1386374224 NOTICE: Skin Helper Service --> BackgroundsUpdater.setPvrBackground --> pvrfanart empty so skipping pvrfanart background untill next restart
L'errore sembra essere legato alla mancanza di un modulo python chiamato cProfile.... che non ho mai sentito....
Prova a dare questo comando via telnet e vediamo se ti restituisce qualche cosa...
opkg list | grep cprofile
niente da fare ho fatto diversi tentativi ho reinstallato immagine pulita ma ogni volta che avvio kodi di mi appare questa maledetta skin chroma che mi blocca il decoder.
Cancella via ftp la cartella nascosta .kodi che hai in hdd. Il suggerimento me lo diede il grande nunigaia per un problema simile con xbmc ;)
Buongiorno, vorrei mandare un saluto a tutti e ringraziare tutto il team per il lavoro che svolgono.
Vorrei darvi una dritta del problema dei plugin che non si avviano a schermo intero. Tempo fa con la blackhole ebbi un problema simile che risolsi installando una skin blackhole che non sia di risoluzione 1920x1080... provate e spero che risolviate il problema.
Rinnovo i saluti a tutti e buona giornata!
