AlexWilMac
Moderator
I wonder if there is a way to read the channels's frequency somewhat.
The reference name seems not having this info, although I see that every channels with same frequency have a field in common, but this hex value is not enough to point at its transponder frequency.
For instance: every Astra 28.2 have in common this final part in their references:
2_11A0000_0_0_0
and, before this part, all the channels with same frequency, has the same value, but it's not enough to get a frquency.
For instance, all the channels (still talking about 28.2E) from 11934V, have 7D7 but this is 2002 in decimal value.
If you consider this channel:
1_0_1_178F_7D7_2_11A0000_0_0_0
if you take away 7D7_2_11A0000_0_0_0 for the reasons I said (7D7 is in common with every channels with 11934V, 2_11A0000_0_0_0 is in common with every other 28.2E) what is left is
1_0_1_178F
but 178F is its SID
In lamedb there are the same fields for each channel, it seems to me.
So... where do I take the frequency info???
I'd like to put all channels from a chosen satellite in order by their frequency, but neither the image has such a feature nor the bouquets' data has this info (because I can read only their ref name, as I said...).
This means there must be some info stored to have this info.
2_11A0000_0_0_0
1_0_1_178F
but 178F is its SID
And, if I'm not wrong, it has only the new channels found. But I'll try, ASAP.
