a911
The BH Lover
Release Total Commander 8.0 release candidate 1 (32/64)
Added:
SelectionFocus=1 or color: Draw focus differently when there are selected files in that panel. Add $4000000 to only show when on not selected item (32/64)
Fixed: Unpacking file from multi-volume ZIP: Don't ask for disk change if the file is in the last part, which contains the zip central directory (32/64)
Fixed: Files - Change attributes: Date field was not focused when checking option "Change date/time" with the keyboard shortcut (64)
Fixed: The program msdvev.exe was incorrectly detected as a self-extracting LHA archive (32/64)
Fixed: Do not re-read active panel (e.g. from background operation) during Ctrl+Tab operation, when user switches through folder tabs (32/64)
Fixed: Multi-rename tool: Text in "Rename mask: File name" box wasn't always selected when opening the dialog (32)
Fixed: Windows 8: Do not resolve links pointing to other volumes in the form "\\?\Volume{" (when double clicking on file, see fix 20.03.12 below) (32/64)
Added: AppendLnk ini option: New value 2 (now the default) sets the behaviour described below. Set to 0 for behaviour as in TC7.x (32/64)
Fixed: When creating *.lnk files, do not truncate directory names after first dot, e.g. directory.ext -> directory.ext.lnk (32/64)
Fixed: OPENBAR command: Support double quotes around parameter (.bar file), do not show "As administrator" (32/64)
Fixed: Handle OPENBAR command in button bar the same way as when specifying the .bar name directly (including "as menu" option and overlay) (32/64)
Fixed: Could no longer close Synchronize dirs after comparing two files (one in a RAR), changing both, and re-packing (32/64)
Fixed: While a MessageBox was open in Lister or Compare by Content, TAB didn't work in TC, and ESC in other Lister windows -> handle it manually (32)
Fixed: Lister: When searching repeatedly for the same string with Ctrl+F (not F3), directly consecutive patterns were skipped (32/64)
Fixed: Improved layout of multi-rename tool a bit (64)
Fixed: Synchronize dirs: Could no longer delete files from UAC-protected dirs to recycle bin (reason: deletion per folder) (32/64)
Fixed: Verify checksums: ESC closed the dialog without aborting the verification (64)
Fixed: Verify checksums: Crashed when user closed main TC and ignored warning about active comparison (64)
Fixed: Nag dialog: Some texts were now in bold by mistake (64)
RgdZ
a911
Added:
RgdZ
a911
