a911
The BH Lover
Release Total Commander 8.01 release candidate 4 (32/64)
Zitat: Fixed: Alt+Shift+F11 cm_FocusButtonbar and cursor keys within button bar: Handle special case where the first and/or last button is a separator (32/64)
Fixed: Changed tcmdx64.exe so it can also be used with TC 8.00 in search results context menu without causing a crash (32)
Fixed: When opening a subdirectory, set caret to first item before adding the new items to the list to avoid a duplicate cursor on Linux/Wine (64)
Added: Internal associations: When context menu is opened while multiple file types are selected, check more filters if the first doesn't match all files, e.g. *.c doesn't match, but *.c *.h further down matches all selected files (32/64)
Fixed: Removed: Default beep on ENTER in inplace rename box (64)
Fixed: Edit current path: Avoid that the in place edit box gets invoked twice (32/64)
Fixed: New delete function: Also hide "Pause" button so the user doesn't pause the operation with Del+Enter (32/64)
Fixed: Also adjust the width of the text field in FTP delete confirmation dialog for very long names with no spaces (32/64)
Added: Experimental: wincmd.ini [Configuration] NetHoodReadInfo=8: Windows Vista/7: Use new delayed method to read virtual network folders, to make it faster (all except for the network neighborhood) (32/64)
RgdZ
a911
RgdZ
a911
