remote control problem
amine2010
hi guys
i need your help.
i have vu+ duo2 with bh 2.1.5 and i have a problem with the remote control it is so slow especially the volume control. i have ole remote control of the solo .is there any way can i use the old remote and is it compatible with duo2.
thanks
Eragon
Vu+ User+++
Use the plugin Remote Control Code (to activate in the BH speedup menu) and then change the code to 1
Thread moved to the BH Duo2 section.
