remove xbmc it's possible?
satdz
hi , after downloading the latest version of blackhole on my solo2 , I have some flash memory , I wonder if there's a solution to remove xbmc ? Thank you.
champ
Note 100% sure but this should work.
Telnet box and type the following: opkg remove enigma2-plugin-extensions-xbmc*
Regards
Moderator
No... absolutely is not recommended!
If you don´t want use XBMC ... never push the plugin button... it will not run.
gawa62
Ok, is Kodi available on other versions like vix? Just nothing seems to work with the outdated version.Thanks
Sent from my GT-I9505 using Tapatalk
Seth_72
works perfect to remove use ftp to remove xbmc but dont start the plugin at all , just remove . Thinks is located on 2 places, have done it my self beacuse dont want internet tv in my satellite box ,
i remove Everything i can to get a blackhole version with out internet tv , stream tv
gawa62
I still want Kodi though Seth_72 but a more reliable version.
satdz
hi , the problem is not there, but xbmc occupies much memory and SOLO2 is already full ; that's why I want to delete it
