Request : auto bouquets
Unibiggle
Just install it. It works fine on my duo BH2.0.1. I had to place the plugin in the folder directly and then chmod 3 files within it to get it to work. Couldn't get it to work via the ipk file
Sent from my GT-I9305 using Tapatalk 2
Nixy82
Call me thick, but I can't see the compiled version
All I can see is source files, what am I doing wrong here?
Unibiggle
Sorry I thought you was after auto bouquets e2 28.2east. If you use this frequency then use this. I've never used the one you linked to
Nixy82
Yeah I have the ipk for the older version which worked for me, I'll upload it for others If I'm allowed (not sure about rules for that sort of thing)
Unibiggle
I have the autobouquets 28.2 Feb version if you want me to upload for you. Do you use sky channels?
Nixy82
Yeah, I think I'm using some 2012 version that I found with the _all.ipk suffix so that would be awesome if you have a newer version.
Nixy82
one question whilst you're online, the one I'm using I found overwrote my bouquets even though I unticked "make default bouquets)
I'm sure it didn't do that before (although I'm not 100% on which version that was) as I have re-ordered the UK 1-100 section and want to retain that
ABM by the OE-Alliance worked with the BP image the last time i tried it, not sure if it will work with BH 2.0.X as i have not yet tried it, but it does not have and dependencies and it's fully open source as per the OE-Alliance. so it's free for the BH team to adapt it to work with their image if they choose to.
Unibiggle
It shouldn't overwrite any existing bouquets even with that box ticked. It just adds new bouquets to your existing ones
Nixy82
Any chance we could get this added to the server?
