Request new development to VU+ Team
I am really disappointed that VU + team still did not enable DTS downmix, improved multimedia and picture quality on SD channels. Without it, story about vu + receiver duo is not rounded, and the worst for VU + would be that the new models have that function,without support for vu+duo. We all know that the DTS on dreambox receivers enabled with the SW hack, so ... I hope that this will occur when the need!
I've just reported this issue once again to vu+.
One more thing. MKV movies 1080p are hanging like in the past. I checked the new image with "Let me in 1080p", "Paranormal activity 2 1080p" - movies hanged about 6-7 times during movie - so video isnt working and DTS audio is not working. Old Image Black hole 1.4.5 was better. Thats all what I want to say. And subtitles during forwarding or backwarding doesn't work. Guys it's realy horrible if you use your VU as HD media player...
DTS Downmix on the one hand, but on the other hand DTS Passthrough via SPDIF and HDMI is also terrible...
I've tested this MKV file on my Duo with BH 1.4.6
Generale
UniqueID/String                  : 213251397923685209074287297860326779377 (0xA06EB9ACE43F62A2A485A12E6609E9F1)
Nome completo                    : Benvenuti.al.Sud.2010.BluRay.1080p.DTS.ITA.x264-Wiggaz.mkv
Formato                          : Matroska
Dimensione                       : 7,95 GiB
Durata                           : 1h 45min
BitRate totale                   : 10,8 Mbps
Data di codifica                 : UTC 2011-02-21 18:29:41
Creato con                       : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
Compressore                      : libebml v1.0.0 + libmatroska v1.0.0
Video
Formato                          : AVC
Formato/Informazioni             : Advanced Video Codec
Profilo del formato              : High@L4.1
Impostazioni del formato, CABAC  : Si
Impostazioni del formato, ReFram : 4 fotogrammi
Format_Settings_GOP              : N=1
Codec ID                         : V_MPEG4/ISO/AVC
Durata                           : 1h 45min
BitRate                          : 9 248 Kbps
Larghezza                        : 1 920 pixel
Altezza                          : 816 pixel
AspectRatio                      : 2,35:1
FrameRate                        : 23,976 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
Tipo di scansione                : Progressivo
Bit/(Pixel*Frame)                : 0.246
Dimensione della traccia         : 6,68 GiB (84%)
Titolo                           : Video Bitrate = 9245 kbps
Compressore                      : x264 core 114 r1900 60ef1f8
Impostazioni compressione        : cabac=1 / ref=4 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9248 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Lingua                           : Inglese
Audio
Formato                          : DTS
Formato/Informazioni             : Digital Theater Systems
Codec ID                         : A_DTS
Durata                           : 1h 45min
Modalità                         : Costante
BitRate                          : 1 510 Kbps
Canali                           : 6 canali
Posizione dei canali             : Front: L C R, Side: L R, LFE
SamplingRate                     : 48,0 KHz
BitDepth/String                  : 24 bits
Dimensione della traccia         : 1,12 GiB (14%)
Titolo                           : DTS ITA 5.1 1509 kbps
Lingua                           : Italiano
Testo #1
Formato                          : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Informazioni            : UTF-8 Plain Text
Titolo                           : SUB ITA
Lingua                           : Italiano
Testo #2
Formato                          : VobSub
Modalità di muxing               : zlib
Codec ID                         : S_VOBSUB
Codec ID/Informazioni            : The same subtitle format used on DVDs
Titolo                           : SUB ITA
Lingua                           : Italiano
Testo #3
Formato                          : UTF-8
Titolo                           : SUB ENG
Lingua                           : Inglese
Menù
00:00:00.000                     : it:00:00:00.000
00:04:50.874                     : it:00:04:50.874
00:10:30.713                     : it:00:10:30.713
00:14:08.765                     : it:00:14:08.765
00:17:58.160                     : it:00:17:58.160
00:21:10.019                     : it:00:21:10.019
00:28:03.765                     : it:00:28:03.765
00:32:06.007                     : it:00:32:06.007
00:36:48.456                     : it:00:36:48.456
00:40:02.400                     : it:00:40:02.400
00:44:52.273                     : it:00:44:52.273
00:49:12.950                     : it:00:49:12.950
00:53:09.186                     : it:00:53:09.186
00:56:52.784                     : it:00:56:52.784
01:00:19.115                     : it:01:00:19.115
01:03:35.270                     : it:01:03:35.270
01:07:30.922                     : it:01:07:30.922
01:12:03.069                     : it:01:12:03.069
01:20:32.953                     : it:01:20:32.953
01:25:09.271                     : it:01:25:09.271
01:29:38.290                     : it:01:29:38.290
01:34:51.102                     : it:01:34:51.102
01:38:11.302                     : it:01:38:11.302
01:41:14.485                     : it:01:41:14.485
The file is taken from the local SATA HDD.
I've connected the box via HDMI cable to my Onkyo (in signature) and I've disabled the audio downmix during the movie play (Audio button -> red button).
My amplifier detect correctly the DTS audio track and no freeze or artifact are detected during play.
The only issue is a little audio lag random during play but the same problem is detected by play the same file with another SAT linux box.
I tried many movies and NOT WORK any with DTS.
My Vu+DUO is connected on my home theather via Audio cable and second way is direct to TV via HDMI. On both ways NOT WORK DTS audio !
Last movie which I tried is "SanctumX264DTS.mkv"...nothing...
And again no fix for DTS in new drivers... :( I hope so for that like said @Tamaki .
Volume control wont work on AC3 channels, it does not make any diffrerence when using volume button on AC3 channels.
HD channels with AC3 knows just two states for volume, on and off.
If you have selected to disable the downmix of AC3 (audio button -> red button) the volume of the box is ininfluent.
I've checked it with some files and SAT/DVB-T HD channels with that setting setted "OFF" (my HT system works great :D)
Yes with Downmix volume works, but it is only stereo. Problem is when watching different channels, volume is high on some channels and you have to adjust your amplifier, but if AC3 sound can be adjusted directly from VU+, you only need to use VU+ remote to adjust volume for all channels.
and if you choose different audio source, eg. DVD-player volume is high for it becouse audio level is different and it cannot be setted with "Automatic Volume Control" plugin. I got yamaha amplifier and with that i can use only preset for audio between -3 - +6 dB and sometimes it is not enough to get all units (DVD, BD, CD, Mediaplayer, VU+) to same audio level.
I would like to have Red Button "Zap" in Single EPG, as it is in MultiEPG & GraphicEPG.
Might seem strange, however I recently discovered that Single EPG for other channels can be browsed using arrow buttons either side of 0/zero key. I really like this way of viewing EPG, but without option to zap, it's a bit limited.
Hi Tamaki
is at any Plan for CI+ Legacy Cam Support?That would be great for Vu+ Team the sales would explode :D
Then we can use our CI+ Cam (Irdeto Provider)on our Vu duo and not other cheaply Receiver.
thx bye
Hi Tamaki
thx bye
Here is the anwser about your question:
CI+ is an issue we need to watch.
The priority of CI+, however, is not set as high because it needs quite resource to support it and we think the support of CI+ as a feature of future model.
Thank you for reminding me of this issue.
I will check the possible schedule again.
Hi
I am surprised which I so fast an answer got.Then wait for future models from Vu Team and until then I must use my second Receiver for CI+ Channels.
Thank you very mouch Tamaki for you Support for the members here in the Blakhole Community. :thanks: :thanks:
thx bye
Hi
thx bye
We have very fast unswers as vu+ is very efficient and careful to users needs
