Hi. The buttons of the volume do not work to me after having manipulated it for the TV.
I need to know the combination to be able to reset the remote control of Vu + Zero 4K.
Thanks for reading me.
Check the Manual of the similar bluetooh remote control, or the Manual of Vuplus Zero 4k.
There you can find the instructions needed to reprogramm your RCU.
