Plugin u installed not compatible with ur box so what u can do is if u can connect to the ur box via ftp delete that plugin if u can't then just re flash ur box pls make sure backup all ur settings befor re flashAfter installing the plugin DUO2 restarts again and again and not get into the menu that I did the factory settings can be reset to factory settings also do differently?
I mean re flash the image via USBThank you for your answer, how do I make a flash or VU + I take in for service?
