Rihanna
Changes in version two Rihanna 1 and 2 will be in all panels added provider logo small picons
(For my work colleague Ed following change)
Good idea, now is better look ! Is this changed skins available on our server with same name or will be like V2 ?
One proposal - please change icon for moving motor, this is old dreambox icon,try some new,maybe vu + :thumbup: Motor icon which use @Army is total ok.
There's still a lot to make for the V2 .
1.Coding and Integration more panels in to PIG panels.
2.Change even more Panel/Menu names in the graphic (font) names
3.Filling the black holes in the panel with adequate icons
especially in the panels with a small PIG monitor.
4. Adding in some Panels/Menu icon symbol
in the lower left corner
e.t.c
Example :
This silver is very elegant and look realy good.
I think that will be great if You add small icons in some panels like in SF10 gold edition because we have now icons in left corner and it would give excellent look with small icons in panels.
Also what do You think to exchange small buttons with this ?
I hope so that You will up this and 2 exchanged versions of rihanna on bh server tonight or tomorow :)
P.S.
Is this icon in customize panel like in Iphone (IOS) ? :) I thinked that You and I not love iphone OS design :)
P.S.
Some idea / ideas that you mentioned will probably be in the V3
version (I had previously planned but requires time)
, depending on the results obtained during the test.
As for the graphics and ICON is a matter of choice
I think this fits well.
Rgd MX
Master tell me, can this picons in the panels be better graphic look ? Some of these are not good look like "history hd".
Strange, on my TV all look the same good .Certainly not bad.
Perhaps they are not crystal clear but it is not the goal.
