Rihanna
Agree 100%!
:thumbup: !
Dzoni Menu :lamo:
GNite
Rihanna 5
Last changes
Replaced deafult picon @Daconi new version (reduced version)
I hope our picon specialists @Daconi and Mmark can find time to make Picone
100x60 format . That best fits in the OSD
Replaced picon illustrations MyTube, DVD and movie player
Finely tuned to the position of all elements of the Menu panels
and other panels.
This skin was created as a result of long work on the development of our coding
on skins and images.
I think this is the strongest skin that I ever made
both style and coding.
I hope you like.
Other color versions will be especially created
(probably red one)
not only the OSD, but also other parts of the skin
such as color buttons, etc.
Of course it will still require time because it is not an ordinary conversion.
Rgd MX
I would like to ask you why you need an SD Picon 80k60 size?
I think that is the optimal size of 100k60 and therefore ask for a reason.
Build in the two versions of Picon and a small gift for the new panel if you like, if not maybe for the next one ...
P.S. Master Files of new picon are in .psd format and pass I send to you in PM..;)
Rgs,
Daconi
My mistake
HD picon 100x60
Red Rihanna need to be with strong red color. Do You plain to use same background or some other ? Maybe black with silever metalic 3d ribon would be good option...
I like yellow/gold one too, but if we'll have blue and red OSD, it's very good, althought if we could have this 3 colours, would be even better. :D
I have transparent picons 100x60, but in Rihanna 1/2/3 (picon 130x80) picons are not centered horizontally, is there any way to centralize them?
Rihanna 5
What you want to have in the Menu
make a choice for channel icons
Under the PIG monitor.
(icons in my last post, or these)
In retrospect maybe we should make a smaller size
button icon .
But first make a choice ??
Buttons or not ??
Later I will make with the smaller buttons
so you can compare
mx,
I like the picons not the buttons
regards
Yes,,,,agree 100% with satspock!
However its very nice design MX10 and may be could be used in future skin but with other graphical design shape!
And the same concept could be used with button of post#133 (BH green panel selections)
RgdZ
a911
