RT3070 driver v2.5.0.1
This patch need only for new driver rt2870 and rt3572. May be for new version rt3070 too but I didn't get stable work from new version.
Driver rt3070 2.1.1.0 works great without this patch.
I'll try rt2870 dongle with rt3070 2.1.1.0 driver this weekend.
But I'm not sure for this solution work.
I read rt3070 dongles work with rt2870 driver but only with addition firmware file.
Sorry for my bad English
Thanks for your support and interest bigroma :)
D-Link DWL-G122 (€ 14,oo) works fine
lsusb
Bus 001 Device 010: ID 07d1:3c0f D-Link System AirPlus G DWL-G122 Wireless Adapter(rev.E) [Ralink RT2870]
CISCO Linksys WUSB100 v2 - doesn't work!
lsusb
I will verify and add the Linksys device in the drivers (USB IDs are 1737:0078 ).
not detect thethe device,
Linksys WUSB600N v1 Dual-Band Wireless-N Network Adapter [Ralink RT2870]
greetings.
Working
Eminent Wireless Adapter
150N USB Adapter
EMM4554
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S: Product=BRCM OHCI
S: SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 1, #Iso= 0
T: Bus=03 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 4
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=058f ProdID=9254 Rev= 3.12
S: Manufacturer=ALCOR
S: Product=Generic USB Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=255ms
T: Bus=03 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=148f ProdID=3070 Rev= 1.01
S: Manufacturer=Ralink
S: Product=802.11 n WLAN
S: SerialNumber=1.0
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=450mA
I: If#= 0 Alt= 0 #EPs= 7 Cls=ff(vend.) Sub=ff Prot=ff Driver=rt2870
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S: Product=BRCM EHCI
S: SerialNumber=ehci-brcm
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
Could you please post the output of the following command?
cat /proc/bus/usb/devices
I need the USB device ids of your WiFi devices :)
Installed Belkin f5D5070 v3, works fine downloading (MyTube, EPG), but cant access vu+ from Telnet, FTP or web interface. I changed IP address in FTP programme etc, but it times out. Any special settings to make it work?
Very strange.
Have you restarted your box after the wifi setup?
In one or two cases, I have must restarted the box to apply wifi settings and access on the box via FTP,SSH and other box services.
Very strange.
I'm sure I must have restarted box at least once...anyway, it was more of an experiment, I've gone back to ethernet, I was planning on moving my router to another room, but that plan has changed.
Good to know it should work simply, for future reference.
Thanks
Device: USB: 0411:00E8 MelCo., Inc. Buffalo WLI-UC-G300N Wireless LAN Adapter
Doesnt work. It doesnt recognize it, if I enable open VPN I can get in to the Wlan menu, but when I choose adaptersettings it crashes.
The support of your device will be included into next BH image.
Hi,
I bought a Sitecom Wireless USB adapter 54g (special compact size edition) and I tried to use it with my Vu+ Duo.
If I go to the configuration menu for the network, I can see only LAN configuration and it says that internet doesn't work.
Should I do something more to make it work or the device is not supported?
Thanks!
This is the code of the adapter: WL-608 v1 002.
I'm using BH 1.4.6
In the attached file you have the output of the following command:
Thanks!
Your device uses the RT2870 driver.
This driver is under testing and will be included into BH 1.5.1.
I haven't had the time to make tests for inclusion into BH 1.5 image.
