S k i n F a c t o r y 10 (Gold edition)
Thanks Matrix10. Yes, you right, I want make a small change in graphics (just a small border in OSD like you made around the picons in Skin Factory 10 Gold edition and Black White SE skin). What you mean with "original skin HI color files"? That color is not a number color of a graphic program? Or you you have your colors made just for BH skins? You can't give me because you can't give it out of BH team or because it is technically impossible? I guess I can see the color numbers in skin.xml, right? But I don't know where I can see those colours. The colour I want put around the OSD is the same you did put around the picons (blue, in SF10_GE, and white, in BW_SE skin) and I can use the magic tool to copy the color, although not the same. You work with a Adove graphic program (Photoshop CS5.1, Fireworks CS5.1, etc) to make graphics in skins?
I have not seen your post earlier
I make my skins with 32bits True color plus Alpha (transparency).
After that I convert a graphic for skin in image
to 256 colors 8 bits .You can not use True color in skin but only 256 colors 8 bits .
If the graphic is transparent, then I have to convert including transparency.
You can use the above programs to change the graphics.
Rgd MX
Matrix​
excuse me for this question​
:suda:​
how can I install this skin ? and where is it, I didn't find the skin file​
:oops:​
Nader​
I'm sorry but I do not have
This skin is no longer on the list for update.
It's too much work for me to make a about twenty + skin updates.
