S k i n F a c t o r y 6 Black
If someone like better buttons form SkinFactory 6 SE skin
you can replace only red/blue/green/yellow but also if you like select button in Menu panels
You have to copy files from my ZIP in to skin folders with the same name.
I'd like to know which you like better that I could use in the final version
Can you explain what you mean? Are you talking about red/blue/green/yellow buttons functions?
I like both :D, but maybe circular look (like physical buttons) as stay now it's more intuitive and better final look. Anyway, circular or rectangular is fine.
Skin Factory 6 black update V2
Update V2 on our image server
change in colors and buttons (agn back to rectangular )
removed shine effect from buttons,icons and clock
Skin Factory 6 BK (black) BH1.4.1/..../1.4.4 V2 (Black Hole E2)
I will upload later for manual installation circular buttons with removed shine effect
Tested,and it looks,,,, FANtastic!
Thanx,,,Prince MX10!
Im sorry i have put agn circular buttons with removed shine effect on orginal skin version
on our server.
It´s only this what change from V1 to V2? Why you removed shine effect? It's due to technical problems it causes (such as slow down for example) or is it just anaesthetic issue?
