S k i n F a c t o r y - S E
Skin Factory SEI V2 (big Current prog info in OSD) BH1.4.1/..../1.4.5 V2 (Black Hole E2)
I made another test version with bigger Current prog info in OSD
(2Xok button)
I'd asked you to test and say which version you prefer
liked
One version will be deleted from the server after this test...
(This version will overwrite old version ,but you can download agn old one
and install.)
I dont know, I do not think that has to do with skin coding
It has no direct relationship to skin coding
but probably with the EPG and coding for the OSD epg info.
It would need someone to investigate.
Skin Update Skin Factory SEI V3
Skin Factory SEI V3 (big Curent prog info in OSD) BH1.4.1/..../1.4.5 V3 (Black Hole E2)
Use 2x OK for OSD info
This is for now the final solution Compromis
for curent program info in OSD
Why compromise
because not all EPG providers use the same text format
for EPG curent info .
Which is of course a problem.
However, this solution will work on most if not with all of the EPG
for which there is information.
Thanks mate, its working now on 28.2 will this work on S k i n F a c t o r y 6 S E bcz i like 6 S E beter
Skin Factory SE Update V2 you can download from image server
Skin Factory SE (special edition) BH1.4.1/..../1.4.5 V2 (Black Hole E2)
Change background graphics in Menu and panels
better readability, quicker menu/panels and a nicer design.
Good friend Matrix10, after making the skin dowload the SEI SkinFactory 1.7.x V1 BH (Black Hole E2), as when putting skin in the deco, green screen system crash and there was no way that this boot again, the reboot system remained constant with the deco VU+ UNO. Thanks in advance ... congratulations on your work
No problem here
:eek:
Im sorry for being a noob... is there a forum guide as to where to get these skins and how to install them??
Ive a Vu+ solo 2...
Thanks..
