sat positioner crashes
You can not use without editing Setting file from another image
in BH image.
Info abt VUsolo
for VUduo is I think the same.
http://www.vuplus-community.net/board/threads/vu-solo-and-a-vbox-2-please-help.5778/#post-48237[/quote]
The BH image restores the settings on the duo even if from another image . That is how I restored my sat positions ,but trying to find them with the BH sat positioner gives green screen...Set the tuner to pedefined press ok, the sat position stays the same ,I think it should change to the one to search for then green screen,only had this problem since 1.7 images
Thats what I cant do as the positioner doesent work, I only use the sat /positions from the other image all else is bh
Seem to have solved the problem,using the bh menu ..extensions, removed the sat positioner software then reinstalled it. positioner now works and no green screen.
