satellite / tuner setup
Im sorry
BUT again
what do you want to get with it ?
You can not use both LNBs at the same time because you have DiSEqC between.
I do not understand the function of the second fixed LNB
when they are connected with one cable from DiSEqC.
the first reason is cabling and second reason is due to here(iran) we have high amount of parazit so we need to install one dish in proper location that we have low amount parazit so the reason is these.
i know i cant use 2 LNB in same time
Ok,
Then you have to use the advanced tuner setup
but I do not know details because I do not have such installation.
Dears
i need to config in black hole for tuner A with attached installed dishes figure
What dieseqc do you use?
here is few ways depends of type of switch that you use
version 1 - this is more frequently used
lnb1----->diseqc1.1------>AA Uncommited input 1
lnb2----->diseqc1.1------>AB Uncommited input 1
lnb3----->diseqc1.1------>BA Uncommited input 1
lnb4----->diseqc1.1------>BB Uncommited input 1
lnb5----->diseqc1.1------>AA Uncommited input 2
lnb6----->diseqc1.1------>AB Uncommited input 2
lnb7----->diseqc1.1------>BA Uncommited input 2
lnb8----->diseqc1.1------>BB Uncommited input 2
Here is example screenshot of this adjustment in vu
Option 2
lnb1----->Uncommited input 1
lnb2----->Uncommited input 2
lnb3----->Uncommited input 3
lnb4----->Uncommited input 4
lnb5----->Uncommited input 5
lnb6----->Uncommited input 6
lnb7----->Uncommited input 7
lnb8----->Uncommited input 8
example for this
etc....
Option 1 works perfect for me using Vu+ Solo with BlackHole 2.1.1 and EMP Centauri 8x1
http://www.emp-centauri.cz/index.php?lang=en&page=prodview&id=82
with satellites.xml generated from
http://satellites-xml.org/ - my favourite
http://satellites-xml.eu/ - alternative
http://sathunter.com/ - FYI
Best regards and thank you Zupy for your original and useful post!
PS: i couldn't do it without you!
Dear in my building we have centralized satellite system which is connected with amplifier. 3 satellite is available Nilesate, hotbird and asaiasat
but when I am tunning only one I am getting either nilesat or hotbird or asiasat. how to get all three tighter.
I am using pli4 image with my vu+duo
