Thanks. But If I do so, I get Cool Info Guide and not Cool TV Guide.Go to the Cool Tv plugin.Press yellow for Tv settings.Go down to Start Cool info with EPG button and switch to Yes.Press Red to save.Restart Enigma 2.
Ok. I will try. that. I guess that MultiQuickButton are a plugin that I can get and use for this ?I've remapped a button to directly recall Cool TV Guide using the plugin MultiQuickButton.
YES! Exact so. Now it work exact as I like. You are my man. Thanks a lot.Correct, you can download it from the Black Hole plugin menu.
