Request Setup CrossEpg as easy as possible
I can't put a link to another forum here. But you will easily find the plugin. just Google for Epg Import plugin and install the latest version.
Select your favorite packages under "sources" then press save and "manual". it takes some time to download everything. Be patient.
I hope BH team put that plugin on the download server to Lake it available for BH images. They have it already on OpenBH (a pre-installed plugin) and works perfectly.
I installed and configured the Epg Import plugin. Seems like it is working. However, when I see my channel list, a lot of channels do not show epg information. Only after I selected the channel (pressed ok) the Epg information is shown.
Is this some kind of configure issue?
