sole se stadby problem
kevsat
Hi does any one has this problem when i put the receiver to standby and after a few hours i try to switch it back on but nothing comes then i switch it off from the back switch and put it on again and it will work fine.
The receiver is only 5 mounths old
Thanks
kevsat
this problem started about 3 weeks ago i have tried to change different software but nothing happend
heartpisc
Hi from spain,,do you sresolve your problem?because I had similar problem and now my box ok,,for me similar 3 weeks,and ufff crazzy,,now is all ok,,confirm me if you need help,,and I will try of help you
house1956
i put the receiver to standby and after a few hours i try to switch it back on but nothing comes then i switch it off from the back switch and put it on again and it will work fine please help me
