Solo 4k and DUR-Line uk 119 LNB
db49er
I have just installed this LNB and discovered that the only ones listed in the configuration pages are 101, 102 and 124. I have tried all of them and manual configuration for many hours but no success. The cable is directly linked to No. 1 LNB input as I thought it best to start with a setup I knew worked with the old LNB. I am using OpenVix but I do not suppose that the image will make any difference.
If anyone has any suggestions they would be much appreciated.
Thank you
The 119 model is not included in the unicable.xml version you have.
Try to find another updated file and exchange the one in usr/share/enigma2.
A user defined install should work with the parameters from the LNB manual:
CH01: 1076 MHz CH09: 975 MHz CH17: 1840 MHz
CH02: 1178 MHz CH10: 1025 MHz CH18: 1880 MHz
CH03: 1280 MHz CH11: 1225 MHz CH19: 1920 MHz
CH04: 1382 MHz CH12: 1330 MHz CH20: 1960 MHz
CH05: 1484 MHz CH13: 1430 MHz CH21: 2000 MHz
CH06: 1586 MHz CH14: 1535 MHz CH22: 2040 MHz
CH07: 1688 MHz CH15: 1630 MHz CH23: 2080 MHz
CH08: 1790 MHz CH16: 1730 MHz CH24: 2125 MHz
CH01 - CH08: EN50494 & EN50607 (Unicable 1)
CH09 - CH24: EN50607 (dCSS / JESS / Unicable 2)
Low Band: 10.70 / 11.70 GHz High Band: 11.70 / 12.85 GHz
Here's one from hxxps://github.com/openatv/enigma2/blob/master/data/unicable.xml
Unpack RAR and put in usr/share/enigma2 folder
