Hi there!
I had my Solo frozen on booting enigma 2 screen, so I decided to flash and start from scratch.
I downloaded the image, flashed it and now it won't start. The green light is fixed and can't turn off.
I tried with 2 versions available and got the same result.
I flashed it with a FAT32 format USB, only the vuplus folder in it. I unplugged the box from power, inserted USB and turned on. It went on until the green light flashed rapidly and then I turned off and disconnected USB.
Probably there is something I'm missing or doing wrong, hope someone can help.
Thanks!
Thanks!
