Solo2 Display
salut les amis vous pouverz me dire si je peut faire defiler lafichage lecd du solo2 merci
warning
Do not ask the same thing in several places
Use English in the English section.
Ne pas demander la même chose à plusieurs endroits
Utiliser l'anglais dans la section anglaise.
it works! editing the lcd screen
but with InfoBarSummary
<screen name="InfoBarSummary" position="0,0" size="132,64" id="1">
<widget source="global.CurrentTime" render="Label" position="0,0" size="132,64" font="Regular;50" halign="center" valign="center">
<convert type="ClockToText">Format:%H:%M:%S-%h.%d</convert>
</widget>
</screen>
thx
hi mate am Spanish and I bought a vusolo2've seen what you've resolved to see the lcd clock Might I spend to replace skin on mine thanks vusolo2 forgive the translation is from google
