Which new feature?Nobody known if these new feature will be implemented also for solo2?
Thank you for the information. I hope it too because I'm a Solo2 owner. Happy new yearI tried to help some friends of mine that bought a solo2, and i have to say that they are all (friends) very very disapointed about
trnascoding quality of that receiver, and when above all i recommend it to them !!
I personnaly have a duo2, and this receiver has nothing to do in term of quality transcoding compare to solo2, with mine i have a proper
quality over the net when transcoding, with that solo2 it's a shame.
I really hopre that vu+ will do something for all those people that bought that box because they are going to the wall with it if they don't
find a solution.
Ok that the duo2 is more expensive, but at the same time when we look at the spec they have the same cpu, it is not only the 1gb difference about
the ram that makes the difference according to me when transcoding.
Well i am disapointed about that honnestly, how come vu+ didn't pay attention to that before spreading it on the market.
Really hope that it will change with future update from them.
I wish you all a very happy new year
denon54
