Sportmax plugin by jav @
sat gr
BH Lover
SPORTMAX bouquet iptv plugin
IPTV channels are transferred directly into the Boquet, then IPTV can be seen
Access and update the plugin for sports channels SPORMAX
Perform for other stations from German to U.S. over Yugo pd plugin update many XXX channels are included.
As ipkg or rar, unzip the folder structure on the eighth.
The userbouquet.favourites.tv will be overwritten:
In contrast, the scale of the user favorites (userbouquet.tv__tv_.tv) are not overwritten.
So invest only a favorite and then copy the channels via FTP from the userbouquet.favourites.tv in your favorite.
Then reboot the box (reboot)
  • enigma2-plugin-extensions-sportmax_1.2_mips32el.ipk
seagate1
it does work in a fashion solo2 bh 2.0.3. if you go to the bottom of your channel list its there in favourites you cannot change language plus ive not got 1 xxxx to work plus its a bit freezing on some channels.
sat gr
BH Lover
every day there are new updates for the iptv channels just run the plugin from plugins list and after restart enigma found all your iptv channels in last bouguets category
seagate1
well since my last post ive ran both plugins from green button. every hour or so but still no xxx plus alot of the channels dont clear. i open plugin as i said and reboot but same result using solo2 bh 2.0.3 am i missing something or is that the way it is.
