Strange trouble with 1.7.7 and 1.7.8
stpierre
Hi to all,
I have tried the 1.7.7 and 1.7.8 BlackHole version on my ultimo with this config.
Tuner A = DVB-S2 with diseqc 1.1 and 10 satellites
Tuner B = DVB-S2 with motor Usals
Tuner C = DVB-T
I have problem with Tuner B, the dish is moving correctly to the position, the quality % is OK but the picture is freezing constantly !
This bug is same on all the satellites.
No problem with Tuner A and C.
No trouble with previous versions : 1.7.6 ---> 1.7.0 with same config. of course !
bojja
I don't have ultimo,but for Tuner B waht setup did you made for usals?You should try diseqc 1.2 even for usals.
stpierre
Thanks "bojja" for reply but I have "No trouble with previous versions : 1.7.6 ---> 1.7.0 with same config. of course !"
i have another problem and that is about internet connection.
after i setup 1.7.8 my connection was disable for those lan or wifi.
is there anybody who could help me?
a911
The BH Lover
If I understood your Q? correctly,,I think its IP Address conflict with other WiFi connections, may be caused by the router!
Try the following,
Menu>setup>system>Net Work>Adopter settings>US DHCP....(@ RC < > , make a change to)......NO!
fumbduck
You should really have started your own thread about your specific problem, now you take attention away from stpierre's problem
stpierre
I have tried with official image : "vuplus-image-vuultimo-20121009062827_usb"
I have the same problem.
Return to BlackHole 1.7.6 and all is ok !
