streaming to pc
kostassatcom
hello,i have vu+ ultimo wilth latest image,How can i stream channels from vu,into pc??using latest vlc??
can i use another programme more easiest???
sunespeg
Install xbmc, it has a tv plug in designed for vu+. This way you get all channels list and epg into your pc/media center. Works really well, with a minimal configuration. Only problem i had was some "zap before stream" in settings, also deinterlace is disabled pr default. I am really pleased, and works better than vlc and other stream clients. This is what you want.
