Struggling with smsusb
arber
In Ultimo and Uno no chance to make smsub to work
Both images 201 BH
In cd of this Siano have a fw which is already inside /lib/firmware and iven if i copy this file no result the smsusb is not on screen to cutomize it.
Any help pls how to resolve this case
  • output.txt
angelofsky1980
BlackHole Driver Specialist
Both images 201 BH
Could you please post the output of the following command?
cat /proc/bus/usb/devices
or
lsusb
arber
here it is
no other usb is on uno other than hdd
root@vuuno:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0001
Bus 004 Device 001: ID 1d6b:0001
Bus 002 Device 002: ID 187f:0202
arber
root@vuuno:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 3.01
S: Manufacturer=Linux 3.1.1 ohci_hcd
S: Product=Broadcom STB OHCI
S: SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 3.01
S: Manufacturer=Linux 3.1.1 ehci_hcd
S: Product=Broadcom STB EHCI
S: SerialNumber=ehci_hcd
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=187f ProdID=0202 Rev= 0.06
S: Manufacturer=MDTV Receiver
S: Product=MDTV Receiver
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=smsusb
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
arber
dmesg
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -839311896
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
usb 2-1: new high speed USB device number 2 using ehci-brcm
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
smscore_set_device_mode: firmware download success: dvb_nova_12mhz_b0.inp
usbcore: registered new interface driver smsusb
root@vuuno:~#
angelofsky1980
dmesg
Use it with care.
root@vuuno:~#
It a PC100 Greek device?
arber
Very strange it worked on italysat vuuno image 4.0
On channel search menu they have an item LCN that is for usb dtt, then at blue panel settings select DVB-T Manager
There you find many usb drivers select smsusb driver and reboot.
On tuner configuration comes the 3rd dvb T
Pitty it is mising on Bh images
angelofsky1980
It's NOT MISSING in BH images but we're using a NEWER version of DVB USB drivers than other images.
For this reason something don't work correctly.
As PC100 Greek devices who uses smsusb driver I think I can fix your device with the same fix.
I need time to build the driver.
arber
Yes drivers for this usbT seem obsolete.
Anyway many thanks for yr efforts to build the drive.
kliti
List of DVB-T models use chipsets SMSUSB:
0x187f;0x0202 - Siano Nice Digital Receiver
0x187f;0x0010 - Siano Stellar Digital Receiver
0x187f;0x0100 - Siano Stellar Digital Receiver
0x187f;0x0200 - Siano N*** A Digital Receiver
0x187f;0x0201 - Siano N*** B Digital Receiver
0x187f;0x0300 - Siano Vega Digital Receiver
0x2040;0x1700 - Hauppauge Catamount
0x2040;0x1800 - Hauppauge Okemo-A
0x2040;0x1801 - Hauppauge Okemo-B
0x2040;0x2000 - Hauppauge WinTV MiniCard
0x2040;0x2009 - Hauppauge WinTV MiniCard
0x2040;0x200a - Hauppauge WinTV MiniCard
0x2040;0x2010 - Hauppauge WinTV MiniCard
0x2040;0x2011 - Hauppauge WinTV MiniCard
0x2040;0x2019 - Hauppauge WinTV MiniCard
0x2040;0x5500 - Hauppauge WinTV MiniStick
0x2040;0x5510 - Hauppauge WinTV MiniStick
0x2040;0x5520 - Hauppauge WinTV MiniStick
0x2040;0x5530 - Hauppauge WinTV MiniStick
0x2040;0x5580 - Hauppauge WinTV MiniStick
0x2040;0x5590 - Hauppauge WinTV MiniStick
0x187f;0x0301 - Siano Venice Digital Receiver
0x2040;0xb900 - Hauppauge WinTV MiniStick
0x2040;0xb910 - Hauppauge WinTV MiniStick
0x2040;0xb980 - Hauppauge WinTV MiniStick
0x2040;0xb990 - Hauppauge WinTV MiniStick
0x2040;0xc000 - Hauppauge WinTV MiniStick
0x2040;0xc010 - Hauppauge WinTV MiniStick
0x2040;0xc080 - Hauppauge WinTV MiniStick
0x2040;0xc090 - Hauppauge WinTV MiniStick
kliti
@angelofsky1980
I have this usb tuner to... "Siano Nice Digital Receiver" Can U make smsusb drivers for VU+ Solo & Solo2 or pls tell me what version of BH work with smsusb drivers for "Siano Nice Digital Receiver"
Thanks in advance!
angelofsky1980
I'm working in these hours to compile the smsusb driver with a fix.
I hope can be ready to be tested during this weekend.
angelofsky1980
Are you ready with drivers for these usb dvb-t stick?
I am waiting also to test
My linux home pc dedicated to compile drivers and other working stuff has gone :(
I will replace it ASAP (next weekend I think) and I will restart compilation for all boxes.
Modifications of drivers aren't looses ... I need only time to rebuild my home server.
