malacai
hey everyone.
i have a vu+ duo
updated bootloader, and flashed BH 1.7.1 a couple a day ago.
and today i flashed 1.7.2.. flash went fine. untill i should reboot.
just "starting" on the screen, and i cant get it to read from usb any more.
tested about 10 differnet usb flash mems today.. all the same. so i went to buy a serial cable.
booted upp vuutils, and flashed. vu utils says "ok" but on the vu says "load failure...."
bah
booted up putty..
boot -z -elf flash0.kernel: 'rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
BCM73350010
012
Shmoo Version=1.9
MEMC-00000000 RW=00000010 WW=0000004A G=00000001 R=00000008 W=00000012
MEMC-00000001 RW=00000010 WW=0000004D G=00000001 R=00000008 W=00000004 #$
3
COPY CODE
A567
BCM97335B0 CFE v2.17, CFE core v2.12, Endian Mode: Little
Build Date: Thu Sep 29 12:01:32 2011 (shcheong@ncsh)
Copyright (C) Broadcom Corporation.
Automatic startup canceled via Ctrl-C
writing vfd
DDR Freq: 395MHz
CPU speed: 405MHz
Memory Config: 32+16 non-UMA
Device Tech: 1Gb
Total memory: 384MB
Boot Device: NAND
ECC: Hamming
Total flash: 128MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
checking usb
CFE> boot -z -elf flash0.kernel: 'rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3`
Loading: 0x80001000/3566980 0x80367d84/144016 Entry address is 0x80346000
TP1 Entry Address at 0x80000ffc = 80346000
Starting program at 0x80346000
<5>Linux version 2.6.18-7.3 (vuplus@team3-server) (gcc version 4.4.3 (GCC) ) #1 SMP Fri Sep 23 03:12:10 KST 2011
Fetching vars from bootloader... OK (E,D,B,C)
Detected 256 MB on MEMC0 (strap 0xe5430060)
CFE EnvVar: LINUX_FFS_STARTAD: 00000000, LINUX_FFS_SIZE: 07600000
CFE EnvVar: LINUX_PART_STARTAD: 07600000, LINUX_PART_SIZE: 00400000
g_board_RAM_size=256MB
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 ebi_war=0 pci=1 smp=1
CPU revision is: 0002a044
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
User-defined physical RAM map:
node [00000000, 09000000: RAM]
node [09000000, 07000000: RSVD]
<5>Reserving 112 MB upper memory starting at 09000000
<7>On node 0 totalpages: 65536
<7> DMA zone: 65536 pages, LIFO batch:15
Built 1 zonelists. Total pages: 65536
<5>Kernel command line: rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3` console=ttyS0,115200
Primary instruction cache 32kB, physically tagged, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, linesize 64 bytes.
Synthesized TLB refill handler (23 instructions).
Synthesized TLB load handler fastpath (37 instructions).
Synthesized TLB store handler fastpath (37 instructions).
Synthesized TLB modify handler fastpath (36 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
Found MIPS counter frequency: 203 Mhz
Using 202.501 MHz high precision timer.
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 141312k/262144k available (2824k kernel code, 120640k reserved, 520k data, 136k init, 0k highmem)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
plat_prepare_cpus: ENABLING 2nd Thread...
TP0: prom_boot_secondary: Kick off 2nd CPU...
Brought up 2 CPUs
migration_cost=1000
NET: Registered protocol family 16
registering PCI controller with io_map_base unset
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 4096)
TCP reno registered
brcm-pm: disabling power to USB block
brcm-pm: disabling power to ENET block
brcm-pm: disabling power to SATA block
audit: initializing netlink socket (disabled)
audit(946684800.330:1): initialized
JFFS2 version 2.2. (NAND) (SUMMARY) (C) 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 22) is a 16550A
loop: loaded (max 8 devices)
brcm-pm: enabling power to ENET block
Broadcom BCM7335 P20 Ethernet Network Device v2.0 Sep 23 2011 03:11:24
Config Internal PHY Through MDIO: 100 MB Full-Duplex (auto-neg)
Broadcom STB NAND controller (BrcmNand Controller)
i=0, CS[0] = 0
brcmnand_probe: CS0: dev_id=ecf10095
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB
Found NAND: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
Found NAND chip on Chip Select 0, chipSize=128MB, usable size=128MB, base=0x
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
mtd->oobsize=64, mtd->eccOobSize=16
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
brcmnand_default_bbt: bbt_td = bbt_main_descr
brcmnandCET: Status -> Deferred
numchips=1, size=8000000
Creating 7 MTD partitions on "bcm7xxx-nand.0":
0x0000000000000000-0x0000000007600000 : "rootfs"
0x0000000007600000-0x0000000007a00000 : "kernel"
0x0000000007800000-0x0000000007c00000 : "boot"
0x0000000007c00000-0x0000000007d00000 : "cfe"
0x0000000007d00000-0x0000000007d80000 : "mac"
0x0000000007d80000-0x0000000007e00000 : "env"
0x0000000007e00000-0x0000000007f00000 : "nvm"
usbmon: debugfs is not available
ehci_hcd_brcm_init: Initializing 2 EHCI controller(s)
brcm-pm: enabling power to USB block
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-0)
drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
- USB h/w setup mode <B>
- USB power enable set for active HIGH mode
brcm-ehci brcm-ehci.0: BRCM EHCI
brcm-ehci brcm-ehci.0: new USB bus registered, assigned bus number 1
brcm-ehci brcm-ehci.0: irq 62, io mem 0x10480300
brcm-ehci brcm-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-1)
brcm-ehci-1 brcm-ehci-1.1: BRCM EHCI
brcm-ehci-1 brcm-ehci-1.1: new USB bus registered, assigned bus number 2
brcm-ehci-1 brcm-ehci-1.1: irq 57, io mem 0x10480500
brcm-ehci-1 brcm-ehci-1.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd_brcm_init: Initializing 2 OHCI controller(s)
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-0)
drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
- Resetting at b0480408
<-- brcm_start_hc
brcm-ohci-0 brcm-ohci-0.0: BRCM OHCI
brcm-ohci-0 brcm-ohci-0.0: new USB bus registered, assigned bus number 3
brcm-ohci-0 brcm-ohci-0.0: irq 63, io mem 0x10480400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-1)
- Resetting at b0480608
<-- brcm_start_hc
brcm-ohci-1 brcm-ohci-1.1: BRCM OHCI
brcm-ohci-1 brcm-ohci-1.1: new USB bus registered, assigned bus number 4
brcm-ohci-1 brcm-ohci-1.1: irq 64, io mem 0x10480600
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new driver pegasus
drivers/usb/net/rtl8150.c: rtl8150 based usb-ethernet driver v0.6.2 (2004/08/27)
usbcore: registered new driver rtl8150
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
TCP bic registered
VFS: Mounted root (jffs2 filesystem).
Freeing unused kernel memory: 136k freed
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
<0>Rebooting in 180 seconds..
now im stuck.. any suggestion. or do i need to throw this in the garbage can?
i have a vu+ duo
bah
booted up putty..
BCM73350010
012
Shmoo Version=1.9
3
COPY CODE
A567
writing vfd
DDR Freq: 395MHz
CPU speed: 405MHz
Device Tech: 1Gb
Total memory: 384MB
Boot Device: NAND
ECC: Hamming
Total flash: 128MB
Initializing USB.
CFE initialized.
checking usb
Brought up 2 CPUs
migration_cost=1000
TCP reno registered
i=0, CS[0] = 0
<-- brcm_start_hc
<-- brcm_start_hc
TCP bic registered
