stuck at starting
1.- start Putty with this config (115200,8,n,1)
2.- Send comand: unsetenv STARTUP
3.- Put new kernel
4.- put image
Enjoy!!!
BCM73350010
012
Shmoo Version=1.9
MEMC-00000000 RW=00000010 WW=00000049 G=00000001 R=00000008 W=00000012
MEMC-00000001 RW=0000000F WW=0000004B G=00000001 R=00000007 W=00000003 #$
3
COPY CODE
A567
BCM97335B0 CFE v2.17, CFE core v2.12, Endian Mode: Little
Build Date: Thu Sep 29 12:01:32 2011 (shcheong@ncsh)
Copyright (C) Broadcom Corporation.
Automatic startup canceled via Ctrl-C
writing vfd
DDR Freq: 395MHz
CPU speed: 405MHz
Memory Config: 32+16 non-UMA
Device Tech: 1Gb
Total memory: 384MB
Boot Device: NAND
ECC: Hamming
Total flash: 128MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
checking usb
CFE> unsetenv STARTUP
*** command status = 0
CFE>
nothing much happened there :/.. any other suggestions?
well i CANT flash from usb.. my box has no "i want to check that lovlie usb pen out before i try to boot thing".. :/
Reflash 1.6.6 via serial, nfi image is available.
If 1.6.6 works then just continue to next step. If not you may have a hardware problem, contact reseller.
Redo the boot loader update
Reflash with 1.7.2
ahh well today i get my vu back "happy happy joy joy".. for 5 minutes.. well the box boots fine and has a cvs version of 2009
but. nah cant get it to read usb.. i am so angry right now.. 2 weeks i been waiting and they cant get the box run proper.
anyone has any suggestions?
You may update the STB CFE and install BH 1.72!
However I would recommend to read few posts @ the forum...and make sure to choose the right update and image for your toy!
And U will have Fun again,,,:dance:!
RgdZ
a911
Try Different Manufacturer USB Stick/Pen/Flash Drives.
The issue may be incompatible USB hardware.
Regards.
Hello,
Is there a trick to be able to send the ctrl+C command while booting. I tried many times. Pressing it like crazy, letting it pressed at boot time etc... but I could not get any prompt.
Here is what I get at the end:
CFE initialized.
checking usb
ACK :
writing vfd
Starting splash screen.
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:mem=48M mem=256M@0x20000000 rootfstype=jffs2 root=/dev/mtdblock0 rw
Loading: 0x80001000/7270688 0x806f0120/124336 Entry address is 0x80577fb0
TP1 Entry Address at 0x80000ffc = 80577fb0
Starting program at 0x80577fb0
**Exception 32: EPC=80577FB0, Cause=00008028, VAddr=00000000
RA=8700C78C, PRID=0002A044
0 ($00) = 00000000 AT ($01) = A0000000
v0 ($02) = 00010000 v1 ($03) = 00000040
a0 ($04) = 870561C0 a1 ($05) = 00000000
a2 ($06) = 8700C800 a3 ($07) = 43464531
t0 ($08) = 80577FB0 t1 ($09) = 8000FFC0
t2 ($10) = FFFFFFC0 t3 ($11) = 87076B08
t4 ($12) = 00000001 t5 ($13) = 87080BB9
t6 ($14) = 8700CE68 t7 ($15) = 3EA95587
s0 ($16) = 8700C78C s1 ($17) = 87010000
s2 ($18) = 00000000 s3 ($19) = 8704E7A8
s4 ($20) = 87150578 s5 ($21) = 87076EE8
s6 ($22) = 87150520 s7 ($23) = 87017B08
t8 ($24) = 000000FE t9 ($25) = 87076B2C
k0 ($26) = 87078FA0 k1 ($27) = 00000000
gp ($28) = 870561C0 sp ($29) = 871503D8
fp ($30) = 87033280 ra ($31) = 8700C78C
*** Waiting for system reset ***
Thanks
BCM73350010
012
Shmoo Version=1.9
3
COPY CODE
A567
writing vfd
DDR Freq: 395MHz
CPU speed: 405MHz
Device Tech: 1Gb
Total memory: 384MB
Boot Device: NAND
ECC: Hamming
Total flash: 128MB
Initializing USB.
CFE initialized.
checking usb
CFE>
