Yes it works but with a Irritating bug.
Please read previews posts .
Regards
Option 5 is working (you have list of subtitle lines) but plugin can not read EPG and do the time adjustment - you have to do it mannualy.Option "5" can not work when we play movie from HDD ?
Thanks Zupy and Dzoni it's actually a very good explaination, I think that I will try both solutions to see wich is the best. Just a precision: Swap file doesn't work only when the ram is full so even if swap is slower than RAM It's not going to slow my VU ?
Thanks so i'll try the plugin. I wish that is going to workYou can see all in system info (blue button/yellow),when SWAP starting to work box use that memory and starting to slow down. Off course if use 1-5% SWAP You can not to feel it,but when percent is higher You will feel it.
It's the second time that happened i think and for some subs only.Never have a problem like that hmm....
Is crash happens always or just on some subtitles??
Put here a crash log...
by me is working, try to uninstall and reinstall it.hi
the pluggin is no more working with me
i flashed the device, and reinstalled it, but still buggin when downloading the subtitles
please confirm if it's working well
