sundtek usb tuner
bokkie
Hi all. I have a sundtek usb tuner which I use for cable on my solo2
I can't seem to find sundtek control centre on the feeds though.
Any ideas on where to find it or get my tuner working?
Thanks
angelofsky1980
BlackHole Driver Specialist
Thanks
Have you asked Sundtek about installtion process? I think it's a plugin developed by them.
bokkie
Thanks for your reply. The reason I ask is that I know some images have the plugin available to download from their feeds. Is there any way I can install the correct drivers to get my sundtek tuner working ?
Use the settopbox installer for it
Windows:
http://sundtek.de/media/ssi.rar
MacOSX:
http://sundtek.de/media/ssi_mac.zip
This will install the latest sundtek controlcenter and driver on any image.
