Terratec Tstick+ (rtl2832u+e4000) and august T205 (rtl2832u+fc0012 or 13) not working
esorven
Hello,
I owned these two keys (especially for sdr) : Terratec Tstick+ (rtl2832u+e4000) and august T205 (rtl2832u+fc0012 or 13)
With latest v4l compiled (http://git.linuxtv.org/media_build.git) drivers, they work on my ubuntu.
Is it possible to have them working on my vu uno (bh2.0.3) working ?
I compiled the recipe (bitbake vuplus-dvb-modules) but the drivers are not included, is there a way to take the drivers from v4l and have them compile into openvuplus (i'm a beginner) ?
Thanks in advance.
Just a tip that i observed on my vuuno, with an extension usb cable on my key (elgato dtt v2) i have no more BER errors. Without it, a lot of BERs...
The info for my keys:
August T205:
lsusb command
Bus 001 Device 002: ID 1f4d:a803 G-Tek Electronics Group
lsmod command:
fc0013 17619 1
rtl2832 13647 1
dvb_usb_rtl28xxu 23888 0
rtl2830 17871 1 dvb_usb_rtl28xxu
dvb_usb_v2 23940 1 dvb_usb_rtl28xxu
dvb_core 106020 3 rtl2830,rtl2832,dvb_usb_v2
and dmesg command :
[ 15.039626] DVB: registering new adapter (Crypto ReDi PC 50 A)
[ 15.054367] usb 1-1: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 15.067393] fc0013: Fitipower FC0013 successfully attached.
[ 15.108718] Registered IR keymap rc-empty
[ 15.108809] input: Crypto ReDi PC 50 A as /devices/pci0000:00/0000:00:1f.5/usb1/1-1/rc/rc0/input6
[ 15.108888] rc0: Crypto ReDi PC 50 A as /devices/pci0000:00/0000:00:1f.5/usb1/1-1/rc/rc0
[ 15.118688] usb 1-1: dvb_usb_v2: schedule remote query interval to 400 msecs
[ 15.121971] IR NEC protocol handler initialized
[ 15.123234] IR JVC protocol handler initialized
[ 15.123739] IR Sony protocol handler initialized
[ 15.124271] IR SANYO protocol handler initialized
[ 15.124817] IR RC6 protocol handler initialized
[ 15.125460] IR RC5(x) protocol handler initialized
[ 15.127422] lirc_dev: IR Remote Control driver registered, major 250
[ 15.128693] input: MCE IR Keyboard/Mouse (dvb_usb_rtl28xxu) as /devices/virtual/input/input7
[ 15.128874] IR MCE Keyboard/mouse protocol handler initialized
[ 15.135803] rc rc0: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 0
[ 15.135810] IR LIRC bridge handler initialized
[ 15.160873] usb 1-1: dvb_usb_v2: 'Crypto ReDi PC 50 A' successfully initialized and connected
For the terratec TStick+:
lsusb command:
Bus 001 Device 003: ID 0ccd:00d7 TerraTec Electronic GmbH
lsmod command:
e4000 13006 1
nls_utf8 12557 1
isofs 39815 1
ir_lirc_codec 12859 0
lirc_dev 19166 1 ir_lirc_codec
ir_mce_kbd_decoder 12723 0
ir_rc5_decoder 12507 0
ir_sanyo_decoder 12513 0
ir_sony_decoder 12510 0
ir_jvc_decoder 12507 0
ir_rc6_decoder 12507 0
ir_nec_decoder 12507 0
fc0013 17619 0
rtl2832 13647 1
and dmesg:
usb 1-1: dvb_usb_v2: 'Crypto ReDi PC 50 A' successfully deinitialized and disconnected
[ 1431.012134] usb 1-1: new high-speed USB device number 3 using ehci-pci
[ 1431.295924] usb 1-1: New USB device found, idVendor=0ccd, idProduct=00d7
[ 1431.295930] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1431.295934] usb 1-1: Product: RTL2838UHIDIR
[ 1431.295939] usb 1-1: Manufacturer: Realtek
[ 1431.295943] usb 1-1: SerialNumber: 00000001
[ 1431.435245] usb 1-1: dvb_usb_v2: found a 'TerraTec Cinergy T Stick+' in warm state
[ 1431.582024] usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 1431.582041] DVB: registering new adapter (TerraTec Cinergy T Stick+)
[ 1431.588293] usb 1-1: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 1431.743835] i2c i2c-0: e4000: Elonics E4000 successfully identified
[ 1431.773115] Registered IR keymap rc-empty
[ 1431.773237] input: TerraTec Cinergy T Stick+ as /devices/pci0000:00/0000:00:1f.5/usb1/1-1/rc/rc1/input8
[ 1431.773495] rc1: TerraTec Cinergy T Stick+ as /devices/pci0000:00/0000:00:1f.5/usb1/1-1/rc/rc1
[ 1431.773637] input: MCE IR Keyboard/Mouse (dvb_usb_rtl28xxu) as /devices/virtual/input/input9
[ 1431.774608] rc rc1: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 0
[ 1431.774615] usb 1-1: dvb_usb_v2: schedule remote query interval to 400 msecs
[ 1431.810513] usb 1-1: dvb_usb_v2: 'TerraTec Cinergy T Stick+' successfully initialized and connected
angelofsky1980
BlackHole Driver Specialist
Hello,
I owned these two **** (especially for sdr) : Terratec Tstick+ (rtl2832u+e4000) and august T205 (rtl2832u+fc0012 or 13)
Thanks in advance.
The info for my ****:
August T205:
lsusb command
lsmod command:
fc0013 17619 1
rtl2832 13647 1
and dmesg command :
lsusb command:
lsmod command:
e4000 13006 1
nls_utf8 12557 1
isofs 39815 1
fc0013 17619 0
rtl2832 13647 1
and dmesg:
Thanks for your infos :)
About your devices:
- august T205 (rtl2832u+fc0013) is suppord from BH 2.0.4.
- Terratec Tstick+ (rtl2832u+e4000): should be supported soon. I will verify if it's possible to support it into next Revision/Image Release
esorven
Thanks. I'm updating to 2.0.4 to test the t205 august (cheap).
The usb 1.1 is perhaps a false positive info because i'm mounting it in a virtualbox ubuntu.
angelofsky1980
No probs :) I've taken only useful infos ;)
Your cheap device should work :) the patch on LinuxTV git is mine :) and tested with help of another user registered on this board
esorven
no luck (stick recognized but no service found : tried dvb-T australia and europe settings) on 2.04 for the t205 august.
dmesg output on the vuuno 2.0.4:
udevd (118): /proc/118/oom_adj is deprecated, please use /proc/118/oom_score_adj instead.
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
usbcore: registered new interface driver dvb_usb_rtl28xxu
usb 1-2: dvb_usb_v2: found a 'Crypto Redi PC50A' in warm state
usb 1-2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (Crypto Redi PC50A)
usb 1-2: DVB: registering adapter 1 frontend 0 (Realtek RTL2832 (DVB-T))...
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
usb 1-2: dvb_usb_v2: 'Crypto Redi PC50A' successfully initialized and connected
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
kjournald starting. Commit interval 5 seconds
EXT3-fs (sda1): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (sda1): using internal journal
EXT3-fs (sda1): recovery complete
EXT3-fs (sda1): mounted filesystem with writeback data mode
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
NET: Registered protocol family 10
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
lsusb output
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0001
Bus 004 Device 001: ID 1d6b:0001
and lsmod
root@vuuno:~# lsmod
Module Size Used by Tainted: P
ext2 57224 0
nfsd 100842 11
exportfs 3976 1 nfsd
ipv6 340132 12
fc0013 5863 1
rtl2832 7115 1
dvb_usb_rtl28xxu 11262 2
dvb_usb_v2 12744 1 dvb_usb_rtl28xxu
rtl2830 6583 1 dvb_usb_rtl28xxu
bh_dvb_core 87354 3 rtl2832,dvb_usb_v2,rtl2830
fpga_directc 57585 0
brcmfb 1127 2
dvb_bcm7413 5091667 4 fpga_directc,brcmfb
procmk 1397 2 fpga_directc,dvb_bcm7413
any clue ?
thanks.
paolino
Vu+ User+++
@esorven: set your correct zone (Europe, Australia, so where you live) and try to load channel settings in your box.
esorven
Tried, but no image (the SNR info alternatively shows 55 % and 0 % and 54 % and 0%....). Sniff.
For example, this setting extract from my lamedb backup (France, paris) works with my elgato eyetv DTT v2 :
TF1 HD
p:MR5,c:000078,c:030078,c:050001
0601:eeee0000:0006:20fa:1:0
TF1
p:SMR6
0701:00c00000:0005:0085:1:0
dmarion
@angelofsky1980: Can you also import R820T tuner support into BH? It comes together also with RTL2832U.
