Another question, Where can I find webbrowser files by dcc Because I did not find it on the list of plugins
or on this track /usr/lib/enigma2/python/plugins/SystemPlugins or Extensions
To uninstall you have to go agn to
Plugins >>Extensions managment>>Network>>WebBrowser>>OK>red button>>red button
and Uninstall with OK.
But there are now appears one problem
you'll delete some python and lib files used by other plugins.
If you erase just plugin and not python and lib files it will not relieve all the space.
So the only right solution is the installation of image again.
You're have loaded image to the top with this webbrowser.
