They use the name of the Image Translation. So if you choose as example Swedish as your main Image language. The week days should also be translated to Swedish
What language have you choosen?
Okey. That is just a fault by meI load only the time and not time and date. So will fix that
It's a beautiful skin!
You can see a correction... repairs, in the upper left corner > when the "source" is the card is ok, but when the "source" passes the network no longer.
I also have the same problem with the day of the week, in this case I can not get it in PT. On the right I was able to change only the "Starts at" to PT, the "Next" I can not.
Really Superb this SKIN ...
I will have a check and fix those infobars issues. The translation problem is due to the use of a thirdparty convert. So I will change that to the regular clock to text converter provided by BH.
Then it should translate if the translation is in your Language choice
The stupid Next: label that does not translate is because there is a : sign in the label
Give me a day or two to make some changes and I hope we can tweak this to a better version.
Tanks for the feedback. It's most valued![]()
Thanks to you Thomas67, I am waiting for News
