DRAGO.NET
BH Lover
V-1.1 TodoDream VU-Duo (Mini Haupauge DiBcom compatible)
V-1.1 Version
Compiled 11/12/1910 (ver-5.4)
Gcc-4.4.3
-Support USB-TDT (Haupauge Mini Compatible with DiBcom) (NO Fly Black)
* Fixed audio-video lag-HD Freeview channels
Hd-Glass-Skin 14 - V-2.94 (sharmman)
Emus Util-Glass Panel (sharmman)
- Location of the **** bin: / usr / UCM_CamSrv_bin
- Location of the scripts: / usr / UCM / CamSrv_script
- Location of the configs: In its usual places (eg iria *****.cfg in / etc
-Fixed time in infobar ecm
"They work all USB
- Addons in the main menu option "Manage Software"
Button-blue:-Panel Glass, Glass Utlidades, etc. ..
Possible Bug:
"So much in this version 5.3 as 5.4, I found that when playing any tax assessment itself is trying to stop, fixed by briefly pressing the backspace key. If so, not only fails gragacion reproduction.
Appreciate to test whether this bug actually exists in the formal basis for the image to report and that the correct VU. Thanks
"I would appreciate that tested the Haupage compatible with the DiBcom chip (haupauge wintv nova T, etc.) Just now I have the ministik and I can not test further, it should work, thanks.
You need only turn the deco, plugged into a USB-USB Freeview and booting should acknowledge.
I upload it as a backup, you ought to configure the network, the portion of SAT tuners, etc. ..
DTT channels from the list are from my area, you ought to do a search and place your favorites in "TNT."
V-1.1 Version
Gcc-4.4.3
"They work all USB
Possible Bug:
