Transmission Torrent Client
Hello,
sorry.
Anyway some error of last screen
In wich version of BlackHole are you installing it
  • 1 - BlackHole 3.0.1
  • 2 - BlackHole 3.0.2
  • 3 - OpenBlackHole 01
  • 4 - OpenBH 04
I presume you are installing it in OpenBH 04, but just only to despite and to replicate the installation.
Hello. could someone kindly confirm transmission plugin is working on VU+? I'm very interested, thank you!
Thanks for the reply.
I installed the 2.84 version but does not allow me to access web interface even if the daemon is started.
What did I do wrong?
After use this program ( Transmission v2.92 ) on my VU+Duo2 like 1 hour RAM memory goes to 90% !
It is this normally !?
I tried to improve with this command "echo 1 > /proc/sys/vm/drop_caches" and memory start from normally but after some minutes same thing happens !
Someone can help me with this problem please ?
My advice is not to force our STBs to behave like they were computers. They are not. We have plenty of ways to download without have to use a device born for a totally different task (whom it does in a excellent way).
Whatever, even old, computer equipped with Linux will do the download task very easily.
Have you tried using the plugin ClearMem
