Hi Mick,
Presumably I should then manually update my channels once a week or so... but then hopefully that will not create new folders like autobouquet does... I will give it a go. BTW I tried that dreamboxedit, very nice, does the same thing as E-channelizer.
Cheers,
Mark.
There is also the possibility of just doing it on the box. It's easy to create a bouquet and add channels to it and rearrange to the order you prefer. Whatever though, if you decide to reflash your box for whatever reason, make a copy of them to somewhere off your box, like to a memory stick, so that you only have to copy them back afterwords instead of starting from scratch.
If you're finding though that bouquets are constantly being overwritten, you can make a copy onto the stick plugged into your Zero. They don't take up a lot of room. Do you have a way to telnet into the box?
